RV.Net Open Roads Forum: Towing: Boat Trailer Tags?
Search only in Towing
Open Roads Forum  >  Towing
 > Boat Trailer Tags?
kohldad
Goose Creek, SC
Posted: 04/17/12 08:58pm Link  |  Print  |  Notify Moderator
In SC, we don't need license plates on boat trailers. If I only plan on pulling the boat in AL, FL, GA, TN, and NC, will I need license plates in those state to prevent getting an unwanted souvenoir?
Photo Albums
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd
2004 Lance 815 (an upgrade from my prev 2005 35' fiver )
DW (homemaker), 1 DD @ Clemson in Civil Eng (Dec 2013) w/SIL, 1 DD Tech Grad (home but employed), 2 DFs (meow)
jspringator
Versailles, KY 40383
Posted: 04/17/12 09:18pm Link  |  Print  |  Notify Moderator
No. They aren't required in KY either, and I have towed my boat on trailer in AL, TN, GA and FL without incident.
Jim & Sherri
05 Jayco Eagle 308 FBS, Dual Cam
2001 Ford Excursion 4.30 LSD,V-10,2WD,RAS,5-Star tuner
Honda EU2000 & EU1000 gensets;
2000 watt Tripp-Lite inverter/charger APS 2012
Saturn SD365 inflatable, 15 hp 2 stroke Yamaha
"Scout" Springer Spaniel
belairbrian
Alabama
Posted: 04/17/12 09:29pm Link  |  Print  |  Notify Moderator
Al registers Boats not boat trailers, thus our boat trailers don't have plates. States should honor your home state's registration laws.
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
skipnchar
Topeka or somewhere else
Posted: 04/17/12 10:25pm Link  |  Print  |  Notify Moderator
If you are legal at home you're legal in all states. The law is like licensing and is reciprocal from state to state.
Good luck / Skip
lawnspecialties
Garner, NC
Posted: 04/18/12 04:38am Link  |  Print  |  Notify Moderator
Boats trailers have license plates in NC. But in the unlikely chance you get pulled, just tell'em you're from SC and you don't need them and they'll tell you to have a nice day.
2011 Ford F450 4X4
2011 Cyclone 370C
SolidAxleDurango
OK, USA
Posted: 04/18/12 04:45am Link  |  Print  |  Notify Moderator
This ^
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
gbopp
The Keystone State
Posted: 04/18/12 04:48am Link  |  Print  |  Notify Moderator
I'm sure they'll make you prove you're from SC...
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/18/12 08:19am Link  |  Print  |  Notify Moderator
Good luck / Skip
This is the correct answer. You only need to comply with the registration laws in YOUR home state. As long as you do that, you are legal in ALL other states.
As far as being hassled, if traveling through a state that requires boat trailer licensing in that state, all the officer needs to see is that your truck has an out of state plate and your boat also has an out of state registration, and they won't give you a problem about the trailer.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Arcamper
Fayetteville, AR
Posted: 04/18/12 09:23am Link  |  Print  |  Notify Moderator
Lived in Columbia SC for 7 years and moved to Seattle. Pulled our boat all the way across this great country and no one said a word.
2007 Keystone Laredo 29RL 5th
2008 Dodge 2500 Quad Cab SLT HD 4x4 6.7 Cummins with EB,6 speed auto
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
1994 Chevy 1500 5.7 extended cab PU
Pullrite 16k Superglide with Super Rail kit
Brakesmart & Prodigy P3
Terryallan
Foothills NC
Posted: 04/18/12 07:06pm Link  |  Print  |  Notify Moderator
Easy to do. SC plates on the TV, and SC DL.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
