RV.Net Open Roads Forum: Tow Vehicles: RAM 5500 "Long Hauler" concept test
Search only in Tow Vehicles
 > RAM 5500 "Long Hauler" concept test
Page of 5
Jarlaxle
New England
Posted: 04/18/12 07:37am Link  |  Print  |  Notify Moderator
I'll take one in green with gas power.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
rjstractor
Auburn, WA
Posted: 04/18/12 08:43am Link  |  Print  |  Notify Moderator
ib516 wrote:
"In the zero to 50 mph pulls, our Long-Hauler ran 18.57 seconds, with a best 30 to 50 mph run at 9.95 seconds (Hurt Locker numbers: Ford -- 21.05/12.64; GMC -- 20.60/11.39; Ram HD -- 23.09/13.90). You can see that the best time for the Long-Hauler was a good bit better than each of the Hurt Locker competitors"
Interesting numbers. Seems like the faster acceleration can be attributed to gearing, even though the 5500 engine is derated to a lower power rating. Makes sense that the 5500 had the slowest run up the hill, although not by much. Looks like a nice truck, but really LONNNGG! I wonder if those guys driving had CDLs, or if they were going cowboy, hoping they didn't get pulled over.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
2006 Ford Escape Hybrid
1998 Saturn SL2 toad
2012 VW Jetta S
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/18/12 09:12am Link  |  Print  |  Notify Moderator
This definitely shows what lower gearing can do, with less power output from the engine. I would want one with the 6 speed manual in 4.44 ratio.
In reality though, I think a 4500 with the 6 speed and 4.10 ratio would have plenty of payload capacity and power to pull even the heaviest of RV fifth wheel trailers, unless we're talking about a converted 40-53' semi trailer....
I wouldn't buy the Long Hauler model. I don't need or want a Mega cab. A regular crew cab is plenty enough cab room.
Instead, I would buy a standard issue crew cab 4500/5500 cab/chassis truck and build a bed for it, either in 60" or 84" chassis length, which means either a 9' or 11' bed. A standard issue cab/chassis truck and an off-the-shelf flat bed with storage boxes, or a home-built bed, would be far cheaper and more useful than the more expensive Long Hauler, with a normal pickup bed.
* This post was edited 04/18/12 09:37am by SoCalDesertRider *
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
larry barnhart
wenatchee. wa usa
Posted: 04/18/12 09:55am Link  |  Print  |  Notify Moderator
recycler wrote:
looks good the hotshot'ers would love it....4x4ord towing that 15,000 lbs horse trailer behind a 3/4 ton would be unpleasant at best
Why would the hot shot'ers want a vechicle that uses more fuel. Lots of them use a 3/4 ton from what I have seen. empty trailers can be towed with the smaller trucks. BUT it would handle anything very well.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
me2
Wherever
Posted: 04/18/12 10:24am Link  |  Print  |  Notify Moderator
305/610 isn't a lot of power.
It seems the thing they liked best about that truck was the air suspension.
My old truck has an 05 Cummins CR 325/610 and a very similar air suspension setup. I can vouch for why they like it.
My new truck is the Ford version of this truck.
08 F350 KR LB CC. Its getting air suspension and a twin turbo/ EFI Live 6.7. About 550 HP and over 1000 ftlbs.
dreeder
Castle Rock, Co
Posted: 04/18/12 10:31am Link  |  Print  |  Notify Moderator
I think the thing looks like something put together by Dr. Frankenstein, aside from that and like mentioned previously in this thread, I could see a market for hotshotter's, contracter's and certain RV'ers.
Wills250psd
walnutcove NC
Posted: 04/18/12 10:45am Link  |  Print  |  Notify Moderator
So you changed the engine and modified it?
me2
Wherever
Posted: 04/18/12 10:46am Link  |  Print  |  Notify Moderator
Yes. Search my posts.
I did the engine swap in my old truck back in 2005. I did the suspension a couple years ago.
I'm just about to start work on my new truck.
* This post was edited 04/18/12 10:57am by me2 *
recycler
michigan
Posted: 04/18/12 11:00am Link  |  Print  |  Notify Moderator
chevman
yep they do use 3/4 tons too.. mine is an ex hotshot truck and going by hitch rails being bent into tacos they hauled way overloaded alot
1968 franklin 11fk
back to my 93 cummins
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 04/18/12 11:09am Link  |  Print  |  Notify Moderator
Here is what I don't get and maybe I'm getting old but what is the big deal if you are a half a second faster in the 1/4 mile with a trailer on the back?
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
Page of 5
