RV.Net Open Roads Forum: General RVing Issues: slide out gap
 > slide out gap
6.7 tow rig
kentucky
Posted: 04/18/12 07:11am Link  |  Print  |  Notify Moderator
This picture isnt the greatest but heres what I am trying to describe. This may be normal, but my previous camper had the same gap all around where the slide meets the body. My new trailer has a small gap up top where you can barely see the rubber seal underneath, and a gap big enough at the bottom you can get your finger behind it. It still seals up as it touches the rubber gasket so I think it might be ok. Any suggestions. My dealer is an hour away so I dont want to go up there if I dont have to
2012 Dodge Ram 2500 Cummins H.O 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
Sooner Schooner
On a Roll
Posted: 04/18/12 07:14am Link  |  Print  |  Notify Moderator
From what I can see, it looks normal to me. Our slide on our Everest looks like that.
2008 Damon Tuscany 4076 40' Diesel Pusher
jetboater454
Camping or home
Posted: 04/18/12 07:29am Link  |  Print  |  Notify Moderator
Do you have the same gap in the front? In pic it looks like it's tight against the trim piece.Mine looks the same as yours. Five years and no problems.
Hunting down a 5th wheel toyhauler
'07 Toyota Tundra
Harley Dyna Lowrider
downtheroad
Pacific Northwest
Posted: 04/18/12 07:34am Link  |  Print  |  Notify Moderator
If it isn't leaking, probably leave it alone...
If it is a Lippert Slide and you want to adjust it, here is how.
Scroll down to page 9.
Slide Out Maunal
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Old-Biscuit
Verde Valley
Posted: 04/18/12 12:50pm Link  |  Print  |  Notify Moderator
Slide Out Maunal
That link is for electric operated slide with a stop can.
Got a link for hydraulic operated slide with piston?
My curbside slide closes tighter at top then bottom.........no leaks/fully seals in/out but when in bottom sticks out a bit.
downtheroad
Pacific Northwest
Posted: 04/18/12 02:11pm Link  |  Print  |  Notify Moderator
Power Gear Pg. 20.....HERE
Lippert Pg. 7......HERE
Old-Biscuit
Verde Valley
Posted: 04/18/12 02:55pm Link  |  Print  |  Notify Moderator
Thanks!!
Lippert Pg. 7 is exactly what I wanted.......kept finding 'electric'
6.7 tow rig
kentucky
Posted: 04/18/12 07:08pm Link  |  Print  |  Notify Moderator
No leaks at all and it appears that it extends and retracts as it should. Thanks for the replies
 > slide out gap
