dobbler98
Ohio
Hi all. Some time ago there was a post on using a material that bonded with old wood to make it strong again. It was in reference to cab-over repairs. I lost the link. Can anyone help?
1993 Minnie Winnie
Class C 24'
Chevy 350
Usually pulling one of my toys
Kemahsabe
Kemah, TX
Rot Doctor?
W4MBG
Williamsburg, VA
look up GIT-ROT also.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
j-d
Sunny Florida USA
Rot Doctor's one I've used.
Git-Rot is more common in retail outlets, but the RD products seem more effective. But heed their advice to use respirator/ventilation.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
dobbler98
Ohio
Thanks very much!
hoz
Indiana
Git Rot and Rot Doctor are both epoxy formulations. Check on any 2 part epoxy resins. Raka,West System, or System 3 come to mind. You can buy 2 part epoxy resin much less expensive than speciality products.
Mix and thin the resin with denatured alcohol, warm the wood with a heat gun and apply the mixture liberally. Multipe coats are recommended. In bad situations I have even applied fiberglass cloth as a reinforcement. The cloth is available from the same people that sell the epoxy.
NOTE: it's important to use EPOXY and not polyester resin.
bingford
Utah
dobbler98 wrote: Hi all. Some time ago there was a post on using a material that bonded with old wood to make it strong again. It was in reference to cab-over repairs. I lost the link. Can anyone help?
Composet Products SLV epoxy
www.delamrepair.com
Queens Carriage
Treasure Coast, FLorida
one other thing. epoxy will bond to polyester, but polyester will not bond to epoxy.
dobbler98
Ohio
Thanks to everyone for the great info and links!
