BUFFALODAN
Buffalo NY
...but it was sold!
http://kz-rv.com/sportsmen/S280BH.html
I found one of these trailers online but the dealer said its sold, has no more, and claims not to be getting anymore in. Dealer is apx. 3 hrs away and there isn't a KZ dealer closer that sells Sportsmen...(closest one only sells the Sportsmen Classics)
Right size, weight, layout, price, etc. Plus it had the fiberglass siding instead of the aluminum siding that the Sportsmen usually come built with. It was a really nice unit priced right (around 20K)
SO, if ANYONE has a TT with this floorplan and the weights are close enough to the Sportsmen that my 1/2 ton TV can still tow it please let me know!
2006 KZ Frontier 2505
2005 Chevy Suburban 1500 Z71 4WD
2011 GMC Sierra 1500 SLE Crew Cab 4WD
1 DW
3DD's
crispyc21
VA
My Keystone Sprinter Select 26BH has the same floor plan and weights about the same. Check them out.
autorot8
N. CA
I'm partial to Prime Time RV. Look at either the Lacrosse 292 or Tracer 2900. Similar layouts and weights.
F-350 towing a Prime Time Lacrosse 296BHS
"Overstating the Obvious rarely helps the Oblivious!"
SilnJohn
Denver
Wlderness, Shadow Cruiser, Passpost and some others all have that floor plan in a 26 model. Main difference would be the bottom bunk is a single not a double
2012 Toyota Tundra Crew max 5.7 Limited
2005 F150 Lariat 4x 5.4L, 3.73 (80K mi 4sale cheap needs.......work)
2003 Nissan Pathfinder
2012 Shadow Cruiser 260BHS
Stephensx04
Elgin, IL
My 2670bh keystone has same plan except a single bottom bunk also. Same weights too. I pull with a 07 Tahoe LTZ
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
Check out ebay, Craigslist or RV Wholesalers. RV Wholesalers may make it worth your while ($$) to travel to IN or MI to pick it up.
APT
SE Michigan
I like the modern variation like I have with the bunks and bath swapped and direct bath/second entrance. Rockwood 2702SS, PT Tracer 2900, Viewfinder 28BHSS, and more. Mine was under $21k OTD including about $1000 of factory options and $1000 of dealer options (Reese WDH and slide awning).
2012 VW Passat TDI
BUFFALODAN
Buffalo NY
Quote: the bottom bunk is a single not a double
I need the double. Also prefer a deep slide with the sofa/dinette. Thanks for the replies all.
109rfan
ny
Check out keystone hideout 27 has similar double single slide and u dinette
