RV.Net Open Roads Forum: Travel Trailers: Upgrade the Brake Controller?
 > Upgrade the Brake Controller?
SilnJohn
Denver
Posted: 04/19/12 09:33am Link  |  Print  |  Notify Moderator
Thanks all for the replies, found a P2 for $75 and P3 for $115. Thinking about just going to the P2 since I don't own anything with hydru brakes.
2012 Toyota Tundra Crew max 5.7 Limited
2005 F150 Lariat 4x 5.4L, 3.73 (80K mi 4sale cheap needs.......work)
2003 Nissan Pathfinder
2012 Shadow Cruiser 260BHS
eric james
Sioux Falls, SD
Posted: 04/19/12 09:50am Link  |  Print  |  Notify Moderator
You can't go wrong with the P2. Get the harness, as easy as using a USB cable.
I've been running a P1 for 7 years now without a problem.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
jerem0621
Sequatchie, TN
Posted: 04/19/12 10:51am Link  |  Print  |  Notify Moderator
Ps. The p2 also does electric over hydraulic.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Gene&Ginny
North Kingstown, RI
Posted: 04/19/12 08:13pm Link  |  Print  |  Notify Moderator
I am another one that went from a Voyager to a P3 and am very happy that I made the change. I understand the P2 is the same as the P3 except for the display so the P2 would also be a good choice.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Canuckss
canada
Posted: 04/19/12 10:15pm Link  |  Print  |  Notify Moderator
I have the exact same truck and trailer although 2011 model years and use a couple year old P2 from our previous truck and trailer and it works like a charm. Not to mention this trailer although bigger by 5 feet and heavier tows much better. Get the P2 same as the P3 just not as fancy of a display Enjoy
E&J push'n wind
San Diego CA, The best climate on earth!
Posted: 04/20/12 12:27am Link  |  Print  |  Notify Moderator
I too bought a P2 vs. the P3 and saved a few $$. For the extra money spend you really aren't getting anything more but a different display (far as I know). Save your money & get the P2. If you feel like you just gotta spend the money then go ahead and still get the P2 and send me the difference. Hey.., only $40 difference but I'll take it.
Wisdom is the right use of knowledge. To know is not to be wise. Many men know much, and are all the greater fools for it. There is no fool so great a fool as a knowing fool. But to know how to use knowledge is to have wisdom.
Charles Haddon Spurgeon
