Daboo
Texas Panhandle USA
LongWeekends wrote: Well that was easy. Thanks guys! Now to look around and find something that looks a little less hillbilly.
whats wrong with a hillbilly...I is one
Served proudly 1957-1965..U.S. Air Force
jtfcons
Washington State (The dry side)
Granted it could use a little clean up here and there but the overall design is pretty clever. Look around and you will soon find that the commercial units have weaknesses as well. I have never seen this one advetised commercially.
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK
Scottish Terrier (Chloe)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Coast.Sw.,
Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
powderman426
ohio
I don't believe you need one if the awning latch is working properly. At least I have never had need for one.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
jtfcons
powderman426 wrote: I don't believe you need one if the awning latch is working properly. At least I have never had need for one.
If I were you I would break out the asbestos shorts.
BillofPA
York, PA
I have that exact thing and it works just fine. I use the awning rod to tighten it when traveling to keep awning from unrolling while on the road. To extend awning I use rod to loosen it. Works great for 8 years and no problem interfearing with awning to tear or damage it. I read one time that there are 2 types of Rvers:those that have had the awning unfurl while driving and those that WILL have it unfurl. I didn't want to be one of those.
Jenny & Bill
2004 H/Rambler Ambassador 34PDD
Cummins ISC330 Allison 6 speed
2003 Chevy Malibu Toad
Our new Yorkie, Daisy.
Dutch_12078
Great Sacandaga Lake, NY
BillofPA wrote: I have that exact thing and it works just fine. I use the awning rod to tighten it when traveling to keep awning from unrolling while on the road. To extend awning I use rod to loosen it. Works great for 8 years and no problem interfearing with awning to tear or damage it. I read one time that there are 2 types of Rvers:those that have had the awning unfurl while driving and those that WILL have it unfurl. I didn't want to be one of those.
You left out the third type of RV'er, those of us that have taken steps to prevent the awning from unfurling before it happens to us.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
TripleE
Traveling the country
Actually it is not redneck engineering. We had one on our other MH. The loop portion is indeed where you put the awning rod to loosen and tighten it. Instead of putting a hole in your roller it clamps down on it to keep the awning from unrolling. It shouldn't touch the awning if properly used so I don't know why you are getting holes.
Bill & Treasa
Our Blog
2005 Winnebago Vectra 40AD
400 Cummins, Freightliner chassis
2004 Suzuki Grand Vitara 4X4
LongWeekends
Scottsdale, AZ
TripleE wrote: Actually it is not redneck engineering. We had one on our other MH. The loop portion is indeed where you put the awning rod to loosen and tighten it. Instead of putting a hole in your roller it clamps down on it to keep the awning from unrolling. It shouldn't touch the awning if properly used so I don't know why you are getting holes.
Thanks! Reread OP regarding the holes.
Michael
Just me, my wife, our 11 year old daughter and our two big, hairy Goldens.
2004 Coachmen Cross Country
370DS - 300HP - 2 Slides
