RV.Net Open Roads Forum: Class C Motorhomes: HELP!!! Greyhawk 31 FS
 > HELP!!! Greyhawk 31 FS
skyman1972
Beaver, PA
Posted: 04/18/12 05:10pm Link  |  Print  |  Notify Moderator
I just walked into my 2012 Greyhawk 31 FS and all was dead. It has been sitting since Saturday and plugged in like I always do. I want to reset the main power cord circuit but don't know where it is. Is it with the other circuit breakers? Everything runs fine on gen power but nothing when plugged in to shore. Leaving for Disney in a few days, so please HELP!!!
Mike& Rose
Lake & Horse country,Blackstone Valley MA
Posted: 04/18/12 05:17pm Link  |  Print  |  Notify Moderator
Try this. When you open your coach door there should be a battery cut off switch near the entry. Hit the switch and all your power should go on if you are connected to shore power. Hope this works.
See you on the road!
marvh
Tampa area
Posted: 04/18/12 05:19pm Link  |  Print  |  Notify Moderator
Why don't you call the dealer? It looks to me that it is still under warranty. And if not, they would not have to start doing a lot of guessing as you can answer their questions. It may be a reset that has popped out. Marvh
marvh
Tampa area
Posted: 04/18/12 05:26pm Link  |  Print  |  Notify Moderator
Mike And Rose
I have never had a motor home that the 120 volt was controlled by the cutoff switch by the door. On mine that is the 12 volt system. Marvh
skyman1972
Beaver, PA
Posted: 04/18/12 05:30pm Link  |  Print  |  Notify Moderator
Problem is there is no power when connected to shore at all. Dealer is 5 hours away!! When the generator is running, the 20 and 30 amp stuff is not working. The fridge, ac and such....I am at a loss...
marvh
Tampa area
Posted: 04/18/12 05:37pm Link  |  Print  |  Notify Moderator
If you have an outside utility compartment, look for a little red reset button. The power went out on our Expedition and it was a simple reset. But I was like you, I never knew that it was there. Marvh
skyman1972
Beaver, PA
Posted: 04/18/12 06:01pm Link  |  Print  |  Notify Moderator
Update...no power from shore or generator. The battery is also not charging. I am guessing its a converter problem, as the dc power seems to be ok, no ac power at all. Disney in a few days and now im in panic mode....
Beverley&Ken
Tottenham,Ontario
Posted: 04/18/12 06:28pm Link  |  Print  |  Notify Moderator
In the converter panel, usually brown steel panel covering it, one of the circuit breakers on the 120v side, is usually the main breaker. One ours, it is the left breaker and labeled MAIN. If it tripped or turned off, you will not have any 120v to the RV. Turn it off and on again to be sure, sometimes if it is tripped you cannot tell by position.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
skyman1972
Beaver, PA
Posted: 04/18/12 07:39pm Link  |  Print  |  Notify Moderator
Upon further review, I looked in the compartment where the converter is and saw a wire that was unpluged. I pluged it in and everything came on....I then went in the house to "educate" my kids on how bad it is to lie. When I went back out to the coach, all was dead again. I went back into the compartment and jiggled some stuff around and the transfer switch started to buzz and all came back on again. I don't see how it was the transfer switch when it really seemed like a converter issue. Either way all is working now and I will call the dealer in the morning and see what I need to do. I love RVs!!!!
j-d
Sunny Florida USA
Posted: 04/18/12 07:44pm Link  |  Print  |  Notify Moderator
Re-set all your 120VAC breakers as suggested. At least in our Jayco, the shore tie cable is permanently attached inside the coach, at the Trasfer Switch and Converter. I wonder about the Transfer Switch. It might have failed in a way that it passes neither Shore or Genny power instead of picking one or the other. 2012? Do you have or can you download Owner Manual from Jayco.com? Does it tell you anything? That new, I'm thinking defective new component, failed connection, breaker or switch missed. Are you comfortable working around hte 120VAC with Meter, Test Probe, or Test Light to try and see how far the power is getting?
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
