RV.Net Open Roads Forum: Truck Campers: propane tank question
 > propane tank question
Halltrail
maryland
Posted: 04/18/12 06:49pm Link  |  Print  |  Notify Moderator
Hey all, I took one of my propane tanks over to the fill station and they checked the date...found out that it is out of date...going on first trip this weekend. Im hoping I can find a place close by to get it re-certified...but am I stuck with this type of tank? I have two. Is there some bracket or conversion I can do to use normal 5 gal tanks?
1994 F350 crew cab, Dually, turbo idi 7.3l, auto, Hypermax cowl, 3" downpipe and exhaust, 4.10 gears, airbags, rancho xl9000 shocks, E rated 235/85 r16 tires.
1999 Lance 810 extended cab, A/C and winter package.
SWD
Land of Living Skies
Posted: 04/18/12 07:04pm Link  |  Print  |  Notify Moderator
Wow! Never seen one of those before!
Photog101
Garden City, Michigan
Posted: 04/18/12 07:08pm Link  |  Print  |  Notify Moderator
That just looks like an older horizontal tank. Mine were re-certified last year at Propane Services. Call your larger propane companies and they should be able to tell you does certifications.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
eubank
Angel Fire, NM, USA
Posted: 04/18/12 07:10pm Link  |  Print  |  Notify Moderator
Looks like a pretty standard horizontal cylinder and seems to be in OK shape. Get in your phonebook and locate a propane dealer (not just a filler) who will also recertify cylinders. Take it there, get it recertified, and you're on the road for another five years (assuming visual recertification).
Lynn
Pics and stuff at my Flickr pages
narcodog
Georgia
Posted: 04/18/12 07:11pm Link  |  Print  |  Notify Moderator
Up until last year most Lance's use them. They are far from old or not used any longer. You propane dealer should be able to tell you where to get it certified. A new tank is about $120.00
Golden_HVAC
Fulltime, CA, USA
Posted: 04/18/12 07:12pm Link  |  Print  |  Notify Moderator
Hi,
Do you have a BBQ? Can the tank from it fit into the compartment on your camper? Or is the place it mounts require all that stuff on the top of the tank to hold it in place?
My suggestion is take along the BBQ tank if you can use it, they sell those at Home Depot around $40 or Costco for $27. It might cost $20 to get your tank re-certified. I think they fill them with nitrogen and leak check them at some very high pressure (say 300+ PSI) or test the sidewalls for thickness with a gauge that measures the sidewalls with electronics - looks like a sona gram machine, but smaller and portable. It can tell if there is rust on the inside of the steel tank, and tell the operator the steel thickness.
Fred.
Old-Biscuit
Across the USA
Posted: 04/18/12 07:30pm Link  |  Print  |  Notify Moderator
Just remember IF you use another tank such as a BBQ type it has to be transported/used in the vertical position vs the horizontal position like your existing tank.
Just get yours re-certified.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/18/12 07:57pm Link  |  Print  |  Notify Moderator
Usually, welding gas distributors sell propane, as well as test and certify tanks.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
clinthia
Flathead County, Montana
Posted: 04/18/12 08:03pm Link  |  Print  |  Notify Moderator
Golden_HVAC wrote:
Hi,
Fred.
Our local Costco fills propane tanks for $10.39.
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
Fishinghat
Western Washington, USA
Posted: 04/18/12 08:12pm Link  |  Print  |  Notify Moderator
Most re-fillers don't check the dates on the tanks, so as a temporary solution just take it to a different place to refill it.
Find out where your county or city does recycling and take the tank there. While there ask if they have any newer tanks and if you can have one. I've done that successfully several times. Can't beat the price. (Some were even partially full.)
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
