RV.Net Open Roads Forum: Fifth-Wheels: fiver frames
 > fiver frames
Page of 8
pressure_welder
brandon
Posted: 04/19/12 11:32am Link  |  Print  |  Notify Moderator
Timothy wrote:
pressure_welder wrote:
Just curious as to weather any of you fellas know who made/makes Gulf stream frames? In particular we have a 2004 27' conquest. Its an 8" Ibeam frame with angle iron cross bracing. It looks sound in my opinion, hopefully she is as i am about to weld on my custom reciever hitch i built to pull our 3500lb boat. I realize weight reduction is attractive for RV manfacturers, but being a welder i know the importance of not skimping on dynamically loaded structures. In my opinion the IBEAM on these trailers should be a minimum of a 1/4" web, and a minimum of 1/4" angle iron cross bracing. So what if she weights an extra 3 to 500lbs in the grand scheme of things. These cracking lippert frames are a great example of a material reaching its max fatigue life due to it being over stressed, OR they use a seriously low grade of carbon steel with alot of carbon hot spots. lol my hitch i am installing will only strength the entire camper frame which is sad really.
Your frame was made by Venture. I thinkg Venture was bought up by Lippert too. Newer Gulf Streams have Lippert frames.
should i be concenered with this frame?
2015 RAM cummins 3500 dually Limited
2018 Montana high country
crestliner sportfish
larry barnhart
wenatchee. wa usa
Posted: 04/19/12 01:19pm Link  |  Print  |  Notify Moderator
WyoTraveler wrote:
You made my point exactly by mentioning Alpenlite. I owned a 2001 Alpenlite 32RL 5Ver. Very well built. Excellent RV. Very few problems. I would buy another one any day. BTW, since Alpenlite built such a great RV why aren't they in business today? Too much quality in this throw away world. Everyone is looking for the cheapest deal they can get. It was difficult for them to make a profit. They cheapened up their product to make a profit, had some major problems, and Alpenlite is no more.
Maybe the alpenlite brand was sold and the new owners switched to Lippert frames and raised the prices and the bank shut them down because of not Paying their bills. I was at the factory just before it was closed. Looked like they had business but not geared for a smart build from what I saw. Two many different rv models being built at the same time. MH, camper and fifthwheels on the same assembly line is not smart.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
pressure_welder
brandon
Posted: 04/19/12 01:35pm Link  |  Print  |  Notify Moderator
Id have to say from a high pressure welder stand point my parents 2005 triplEE topaz is by far the most stout frame ive seen, overall quality is outstanding.
lrash
Virginia
Posted: 04/19/12 04:19pm Link  |  Print  |  Notify Moderator
OK I am stupid but where would one look to see who manufactured a frame?? I have a Montana.
bailer6334
Prescott, AZ
Posted: 04/19/12 04:58pm Link  |  Print  |  Notify Moderator
I believe Montana frames are made by Lippert. Have seen several owners report frame problems on here. I suggest you contact the factory to confirm frame supplier.
2017 Grand Design Imagine 2150RB
2016 Chevy 2500HD LT 6.6L DMAX 4WD
Equalizer 4 Point WDH
laknox
Arizona
Posted: 04/19/12 05:48pm Link  |  Print  |  Notify Moderator
The builder plate is on the the permanent part of the pin box on my Komfort. Zieman frame.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
bradyk
Calgary, Alberta
Posted: 04/19/12 06:16pm Link  |  Print  |  Notify Moderator
Zieman is Lippert as well.
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Equal-i-zer 10K WDH
Champion 4000W Generator
Champion 2000W Generator x 2
Ken & Sandra
Yugi Dog, Jet Dog
Timothy
Wisconsin
Posted: 04/19/12 07:07pm Link  |  Print  |  Notify Moderator
I would say no, I never heard of any problems with Venture.
pressure_welder
brandon
Posted: 04/19/12 09:14pm Link  |  Print  |  Notify Moderator
I went and took a closer look at the campers in the shop, My gulf stream conquest, and my parents triplee topaz had "lippert" stickers on the pin box. Although mine also had a "fabex" 15,000lbs sticker on it also. It really is disgusting how stupidly light these frames are built. I beleive ill be doing some reiforcing of my own after i finish installing the reciever for the boat. Id love to lift the whole camper off the frame, ditch the stupid 8" ibeam and replace it with 2" x 6" x 1/4" wall structural tubing. I sure hope this frame dosent disintigrate on me!
SoCalDesertRider
Arizona desert
Posted: 04/20/12 01:57am Link  |  Print  |  Notify Moderator
If I were wanting a big fifth wheel RV trailer, I would be looking at commercial gooseneck enclosed cargo trailers, which have much heavier built frames, with real structural i-beams, not the ultra thin fabricated i-beams the RV industry uses, and build out the inside of it into an RV....
Another way to go would be to buy a used commercial semi trailer, a super insulated 'reefer' model, which already has an awesome air conditioner mounted on the front of it, and build that into an RV...
Either way, at least you know the thing isn't going to fall apart! [emoticon]
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Page of 8
 > fiver frames
