RV.Net Open Roads Forum: What gas / octane do you run in 5.7 hemi
Search only in Tow Vehicles
 > What gas / octane do you run in 5.7 hemi
doctarie
Newark,Ohio
Posted: 04/18/12 08:00pm Link  |  Print  |  Notify Moderator
Just bought 2011 ram big horn with the 5.7 hemi. Was just wondering what you guys are running in yours and why . What gets better mileage , fuel brand , 87 or 89 or 91 .
Thanks Bob
hotpepperkid
Chino Hills CA
Posted: 04/18/12 08:22pm Link  |  Print  |  Notify Moderator
What does your owners manual say
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
eHoefler
ozark mountains
Posted: 04/18/12 08:24pm Link  |  Print  |  Notify Moderator
In our 2012 Durango with the 5.7 Hemi, the owner's manual says to use 89 octane. We have found that there is no difference in performance or economy when using 87 octane.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
bmanning
Phoenix, AZ
Posted: 04/18/12 08:28pm Link  |  Print  |  Notify Moderator
I ran 91 for years in my Land Cruiser, then a while back experimented and switched to 87 which I've run ever since...could be psychological but I feel it actually runs better on 87 and there's been no change in MPG at all.
I know you asked specifically about your Hemi but just thought I'd share my experience, as I now feel that running all those tanks of 91 was a waste of money!
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
archie780
Edmonton
Posted: 04/18/12 08:49pm Link  |  Print  |  Notify Moderator
* This post was edited 04/26/12 08:43pm by archie780 *
Bionic Man
Colorado
Posted: 04/18/12 09:11pm Link  |  Print  |  Notify Moderator
I ran mid-grade (87 in Colorado) on my grand Cherokee and 300.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
mowermech
Billings, MT
Posted: 04/18/12 09:20pm Link  |  Print  |  Notify Moderator
I have the choice of 85.5, 88, or 91
88 is the cheapest, so that is what I run.
We are at 3500 feet altitude or higher.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Eurocamper
Salt Lake City, Utah
Posted: 04/18/12 09:43pm Link  |  Print  |  Notify Moderator
Thanks Bob
I'm running 87 in my Ram 2500, which is mid-grade at the elevation I live at. The manual says 87 is acceptable, while 89 is recommended.
I'm heading up to Yellowstone in a couple weeks and plan to experiment with running premium. In theory, an engine with variable valve timing like the Hemi can adjust to higher octane and produce more power and better throttle response. I'll see if there is a noticeable difference.
2008 Fleetwood Evolution E1
2011 Dodge Ram 2500 Crew Cab 4x4 Hemi
2007 Nissan Xterra 4x4
Ex 1997 Volkswagen Eurovan Camper
Turtle n Peeps
California
Posted: 04/18/12 10:38pm Link  |  Print  |  Notify Moderator
Eurocamper wrote:
Thanks Bob
Your going the wrong way with octane. The higher up you go the less octane you need. That is why places like Denver has less octane in their gasoline.
outside the fire"
HouseApe
Vancouver
Posted: 04/18/12 10:44pm Link  |  Print  |  Notify Moderator
Due to the price I only run 89 when towing and 87 when not. I have towed with 87 and get slightly less (like 0.2) MPG. With 89 you can have more timing giving more power. On the Dodge forum they say continued use of 87 will cause the EGR to carbon up and possible piston damage. But everyone I know that has a HEMI runs 87 for normal use and has no issues.
You guys in the US think gas is high...In Vancouver Canada
87 is $5.44/g
89 is $5.81/g
Diesel is $5.67/g
2007 Dodge Megacab Laramie 4x4 5.9 Cummins
2008 Cougar 301BHS
Reese Straight Line
Tekonsha P3
