RV.Net Open Roads Forum: Towing: Scooter towing/hitch
Search only in Towing
Open Roads Forum  >  Towing
 > Scooter towing/hitch
CathyGo
Arizona/Texas
Posted: 04/19/12 02:45am Link  |  Print  |  Notify Moderator
I'm looking for a hitch mount that will accommodate my scooter. It is a Yamaha Majesty with a weight of about 500lbs. Think motorcycle with smaller front wheel rather than moped. I'm having trouble finding anything that will handle that weight along with the smaller wheel size. Most have a max capacity of 500 lbs and I would like a wiggle room of a few hundred pounds at least. Is this a hitch capacity limit or have I just not found the right one yet?
skipnchar
Topeka or somewhere else
Posted: 04/19/12 06:14am Link  |  Print  |  Notify Moderator
some class IV receivers have a much higher rating but they MAY not fit your tow vehicle. Of course with a welding torch most ANYTHING can be made to fit. If you can't find a class IV that will fit your vehicle then you may be able to find a class V that will.
Good luck / Skip
Beverley&Ken
Tottenham,Ontario
Posted: 04/19/12 07:53am Link  |  Print  |  Notify Moderator
What type of vehicle do you have? Most cars, 1/2 ton pickups and A-class gas MH have a vertical, tongue weight of 500lbs. Even then a class4 receiver may fit, but still would not raise the capacity about 500lbs.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Hank85713
Tucson, Az
Posted: 04/19/12 08:36pm Link  |  Print  |  Notify Moderator
See if this helps and then you can call these folks.
http://www.etrailer.com/Hitch-Cargo-Carrier/Ultra-Fab%20Products/UF48-979033.html
CathyGo
Arizona/Texas
Posted: 04/20/12 12:23pm Link  |  Print  |  Notify Moderator
Though I'd found something at that site but then it specifically stated that rear engine mounted scooters weighing over 300 lbs wouldn't word with it. Oh well, the search continues.
Hank85713
Tucson, Az
Posted: 04/20/12 01:24pm Link  |  Print  |  Notify Moderator
Cathy go, call them they are pretty good to deal with. If they cant answer they may be able to get to someone who can!
