RV.Net Open Roads Forum: Towing: Installing the superglide 18k on Sunday.
Search only in Towing
Open Roads Forum  >  Towing
 > Installing the superglide 18k on Sunday.
porkchop1221
US
Posted: 04/19/12 07:23am Link  |  Quote  |  Print  |  Notify Moderator
We should be getting the hitch on Friday and installing it sunday.
Tweetys was Excellent with the purchase and the quick delivery! I'm very happy with them!
But I'm wondering if anyone has any tips or tricks or anything that we should consider.
It's the superglide and super rails set up.
Thanks!
2012 GMC 3500HD, Diesel, Crew Cab Standard Bed, SRW
2013 Cyclone 3010 (to be picked up)
chuggs
Posted: 04/19/12 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I think the super rail under bed brackets will make alignment a non-event.
Wear safety glasses...
Every time I go to the sink to rinse out a fresh cut...my son likes to ask, "Dad, were you wearing your gloves?".
Yeah, I'm pretty bad about that.
Post pics!
powderman426
ohio
Posted: 04/19/12 07:58am Link  |  Quote  |  Print  |  Notify Moderator
You only get one chance when drilling the holes. Im not familiar with the super glide, but I imagine the rail attachment isn't much different. Be sure to put the spacers in the bed channels. Have fun.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
porkchop1221
US
Posted: 04/19/12 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I think Pullrite said the superrails use 'existing holes' which I couldn't find any. But I wasn't really looking...
Do I need to buy a specific drill bit?
We are also 'installing' running boards/steps (I'm short, 5'5" and the GMC is HUGE. I basically FALL out of the truck) and a few other things on Sunday.
I'm so excited! I probably won't be doing much of the work, but I will take some pictures and post it.
Arcamper
Fayetteville, AR
Posted: 04/19/12 10:03am Link  |  Quote  |  Print  |  Notify Moderator
It will probably use existing holes in the frame but you have to drill holes in your bed to match up with the mounts. Trust me, use a very small drill bit at first to make sure you are center before drilling the big ones. I have done this now on my Ford and Dodge and measurment is critical. You know the old saying " measure three times cut once"
2007 Keystone Laredo 29RL 5th
2008 Dodge 2500 Quad Cab SLT HD 4x4 6.7 Cummins with EB,6 speed auto
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
1994 Chevy 1500 5.7 extended cab PU
Pullrite 16k Superglide with Super Rail kit
Brakesmart & Prodigy P3
Kennedycamper
Algoa, Texas
Posted: 04/20/12 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on the Measure 3 times before you drill.
J-mans Dad
SF Bay Area
Posted: 04/21/12 12:00am Link  |  Quote  |  Print  |  Notify Moderator
When you get the hitch in, make sure you mark the positions of your bars in relation to the stub ups. LF/RF, LR/RR. otherwise it'll drive you nuts trying to figure out why the pins don't align and the hitch looks wacked.
bigjettech
Bartlett,Il
Posted: 04/21/12 08:13am Link  |  Quote  |  Print  |  Notify Moderator
My 06 Silverado needed drilled, no predrilled holes in the frame. I don't remember the bit size, it's in the directions. There wasn't much choice where the brackets went. The trickiest part is getting the holes drilled in the bed in the correct location. Read though the instructions and understand them before you drill. They give you a good tip on how to get the bed holes lined up properly with the bracket holes.The hole saw is hard to keep on track when drilling the holes, they always seem to end up half on half off the corragated floor.
2006 Silverado 2500hd duramax 4x4 - with a few mods
2006 Cherokee lite 285b+ 5th wheel
ninemmbill
Henderson, NV
Posted: 04/22/12 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Get a good drill and drill bits. The frame on my Ford was tough.
porkchop1221
US
Posted: 04/22/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone! It's slated for next weekend since its pouring out and cold. Our friend is a huge tool fanatic and has pretty much everything under the sun. He and his daughter rebuilt an old Porsche and she did the welding! Anyway. We bought the drill bit, actually two of them and will post pictures when we start the process.
Also I did a short ride with the truck and wow is the ride rough! I can't imagine how it's going to be with the 5th Wheel. I hate to ask the question, but airbags make it better?
I'll try to do a forum search about it too.
Thanks!
