sidecar53
windsor
Hi, guys. I have a 2008 12 foot Jayco popup that the factory stickers are peeling on, so I took my heat gun (being very careful, of course) and removed them. The problem now is that they've left a sticky residue and I'm wondering what I can use to get rid of it without harming the gelcoat. Can I use lacquer thinner or varsol or do you think that it would harm the surface? Thanks in advance for any and all responses.
Moved to Tech Issues forum from DIY.
edited 04/19/12 03:59pm by an administrator/moderator *
downtheroad
Pacific Northwest
Available most anywhere...Walmart, Home Depot, etc.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
ky-newbie
Central Kentucky
Peanut butter works well on most things. Dunno about an RV finish, though.
82corvette
Southeast Nebraska
Goo Gone, available at most hardware stores & WD40 worked good for me.
powderman426
ohio
That's what I would use. Be sure to try a little in a non noticeable place first so your sure it isn't attacking the finish.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
bedrocker
lompoc ca
Use an eraser wheel
CincyGus
Cincinnati
downtheroad wrote: Available most anywhere...Walmart, Home Depot, etc.
2X
Also have used lighter fluid on stickers before on glass and metal. Might try that is a small test area. Wipe it down with a quick scrubbing action and follow with a wet cloth. Worked very well on my Starcraft popup which had Aluminum painted skin on the outside.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
robatthelake
Vancouver Island
Regular Gasoline on a Rag will also work. Wear Rubber Gloves and don't breathe in the fumes. Also don't smoke while using this method.
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
the bear II
Torrance CA.
I used mineral spirits available at most hardware stores. A little goes a long way. Removes the gum with just a little elbow grease and it leaves the siding nice and shiney.
sdianel
Tampa, FL
Ditto Goo Gone! We used it to remove 3M mask glue on the front of our RV (after we heated and scraped the stuff off!)
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
