Where can I find the R134 capacity specs for my 2003 Fleetwood Revolution? This is the engine operated A/C. I can get it close but would rather have the factory specs.
Good luck with that. I have not been able to find that info for my Fleetwood Excursion. Although I have not called trhe factory, they may be able to help. I bought a set of gauges and refilled until be pressures were in the correct operating ranges.
I have a 2003 DP also and I assume there are only so many A/C units used. Under the front hood where the black housing is that covers the blower, coils, etc. there was a sticker with the unit specs. One of the pieces of info on that sticker was the refrigerant capacity. I had my A/C evacuated and refilled with the exact amount and it was very gold after that. The gauges originally were misleading and there ended up being too much freon in the system. Check to see if there is a sticker in that location.
Dan & Tracy
2 kids ages 9 and 11
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
Randy A wrote: Good luck with that. I have not been able to find that info for my Fleetwood Excursion. Although I have not called trhe factory, they may be able to help. I bought a set of gauges and refilled until be pressures were in the correct operating ranges.
