RV.Net Open Roads Forum: Owners Manual Magic Chef Micro/ Convection Oven
 > Owners Manual Magic Chef Micro/ Convection Oven
Gypsy1
Cochran GA
Posted: 04/19/12 08:32pm Link  |  Print  |  Notify Moderator
Need owners manual, installation and or service guide for Magic Chef microwave/convection oven model M71C-10 (1988) installed as OEM HR and other class A's in the day. Mine suddenly quit working , no power, no clue?
Any advise would be appreciated . Also would like to hear anyone's experiance with replacement units and where available?
Winny, Journey WKP32T, Cummins ISB 275 HP, Allison 2000MH, 5 speed Auto, Raptor Air Dog fuel pump, towing 2012 Nisson Xterra 4X4 Auto W/ drive shaft disconnect!
vegasfoodguy
Reno Nv
Posted: 04/19/12 08:44pm Link  |  Print  |  Notify Moderator
Did you plug something else in the outlet to see if it's hot? Plug should be in the cabinet next to Microwave.
Terry
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee and Jeep Wrangler, Brake Buddy.
mowermech
Billings, MT
Posted: 04/19/12 10:06pm Link  |  Print  |  Notify Moderator
Go to the Magic Chef website, you should be able to download the manuals, if they are available.
CM1, USN (RET)
Daily Driver: '06 PT Cruiser Turbo
Toy: 1999 Dodge QC LWB, Cummins, Automatic, 4X4
Other toys: a pair of Kawasaki Brute Force 750 ATVs.
Executive
Posted: 04/19/12 10:24pm Link  |  Print  |  Notify Moderator
You said it stopped working. Is there no power or does it shut off at 59 seconds...[emoticon][emoticon]...Assuming it doesn't work at all...Check first to see if your OUTLET is live. Plug something else into it or use a meter. If it's still hot, then you can proceed with trouble shooting the microwave. If not, then first check your inverter to make sure there's no breaker popped. I've even gone so far as hooking up an extension cord to the microwave and see if it works. Rule out the easy stuff first. Does the front TV work...[emoticon][emoticon]...Remember the microwave and TV are usually on the inverter circuit.....Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
TripleE
Ohio
Posted: 04/20/12 09:14am Link  |  Print  |  Notify Moderator
Try this website. I have found a lot of good manuals here.
Bill & Treasa
Our Blog
USMC Retired MGySGT
2005 Winnebago Vectra 40AD
400 Cummins, Freightliner chassis
2004 Suzuki Grand Vitara 4X4
TEO
Inverness, FL, USA
Posted: 04/20/12 09:22am Link  |  Print  |  Notify Moderator
I had that problem with a Magic Chef several years ago. There was a blown fuse, like an old automotive, glass tube fuse. I replaced it and never had another problem.
Paul
Paul & Helen
2002 Winnebago Journey DL">
1999 Jeep Cherokee toad ">
Yellow Lab, Jodie, Chocolate Lab, Coco ">, and Lab/Golden mix, Sandy.">
FMCA 98905
http://ptempesta.blogspot.com
