RV.Net Open Roads Forum: Travel Trailers: Plugging TT into House
 > Plugging TT into House
Page of 5
SkyPiGG
Southeastern PA
Posted: 04/20/12 06:46am Link  |  Print  |  Notify Moderator
If I have the right adapter, can I plug my TT electrical connection (30 amp) into one of my house sockets (15 amp) just to charge the battery? Obviously, I wouldn't turn any applicances on.
Sorry if this is a stupid question. A friend of mine said that she does it, but wanted to hear it from soneone else.
SkyPiGG
2011 Keystone Cougar XLite 26BHS
2011 Silverado LT 1500 Crew Cab 5.3 V8 HD 3.42 (King George)
Fastway E2 10k Hitch
boosTT
Milwaukee
Posted: 04/20/12 06:55am Link  |  Print  |  Notify Moderator
I do.
jmanneff
Spokane, WA
Posted: 04/20/12 07:00am Link  |  Print  |  Notify Moderator
I am plugged in now, have been for a couple of weeks. We use the furnace and stereo and lights while we're in it cleaning or packing.
samsphones
north carolina
You can also run everything except AC and water heater.
2006 Chevy 3500 4x4 Duramax/Allison transmission
2011 Open Range Roamer 287RLS
Prodigy Brake Controller
B&W Companion 5th Wheel Hitch
Sandia Man
Rio Rancho, NM
Posted: 04/20/12 07:01am Link  |  Print  |  Notify Moderator
No problem, we're plugged in 24/7 when our TT is stored at our home.
coolmom42
Middle Tennessee
Posted: 04/20/12 07:08am Link  |  Print  |  Notify Moderator
I plug in for about 48 hours every couple of weeks. Keeps the battery topped off and ready to use.
2006 Toyota Sienna
Single empty-nester in Middle TN
gbopp
The Keystone State
Our Southwind is plugged in to a 15 amp outlet. It keeps the batteries charged and causes no problems.
Terryallan
Foothills NC
Posted: 04/20/12 07:24am Link  |  Print  |  Notify Moderator
I do it all the thime. I (horror of horrors) even run the AC. In 13 years of doing so. It has not hurt it. As long as the breaker don't trip. Good to go.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
RoyB
King George, VA
Posted: 04/20/12 07:28am Link  |  Print  |  Notify Moderator
I do it all the time here for two trailers when they are not on the road...
All you need is heavy duty 10-gauge (10-3) extension cord and get a RV30A-15A 18-inch long adapter(WALMART)... Make sure you use a good heavy duty extension cord. the cheap 14 gauge extension cords will get hot on you.
Dont use the short round black adapters - they get hot on me..
I have my trailers plugged into the standard garage 120VAC 15AMP receptacle. I can run everything including air conditoning but the trick is you can't run two heavy current items at the same time or you will trip your garage circuit breaker.
I have a 120VAC plug in voltmeter in the trailer and if it is running in the GREEN SAFE SCALE then I can use the air conditioner.
This is good to carry with you on RV trips as well. You never know when this might come in handy. We plug in to our familys garage when visiting and sleep in the trailer.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Playtime II
No. VA
Posted: 04/20/12 07:39am Link  |  Print  |  Notify Moderator
Check you main box first. Most outlet circuits now a days are wired and breakered at 20A as there are more outlets on the circuit or high demand circuit like the Kitchen and Bath outlet circuits. Depending on where you plug in and what is running on that house circuit you may be able to run the A/C in the TT. IF you do, make sure that if you use an extension cord it is 12ga (or 10ga) and not 14ga. Feel the cord, if it is warm continue to monitor it. If it gets hot, stop and get a thicker cord and re-check.
Playtime IV
2006 HR Scepter 42DSQ
Page of 5
