RV.Net Open Roads Forum: Folding Trailers: Hard Sided PUP Question
 > Hard Sided PUP Question
xteacher
Newnan, GA
Posted: 04/20/12 08:44am Link  |  Print  |  Notify Moderator
DH and I have had almost every type of pull behind trailer, and now we're looking at the hard sided PUPs. We like the Aliners, but they're pretty pricey, as are the Trailmanors. The Trailmanors are also a little too heavy for our tow vehicle.
We've also looked at a Flagstaff hardsided PUP, which we liked the features and the price of, that looks like an Aliner. However, when we looked underneath, it wasn't sealed like the Aliner, and we're worried about water leaks/damage. It looked like wood underneath that had been painted with the black water repellant stuff. Not sure if that's enough to do the job. The Rockwood hardsided PUP is the same as the Flagstaff, I think.
Does anyone have experience with any of these PUPs, and if so, what is your opionion of the Flagstaff/Rockwood ones, as far as water tightness is concerned?
Thanks for any advice you can provide.
Beth ('57)
DH ('55)
Fur Kids: Potsie (poodle), Maddie (westie mix), and Dempsey (boxer)
2012 Aliner Classic
2010 Nissan Pathfinder
lfloom
Pasadena
Posted: 04/20/12 09:57am Link  |  Print  |  Notify Moderator
Might want to ask here:
Forest River Forums
beemerphile1
I'm 57, I'm not a
Posted: 04/20/12 11:03am Link  |  Print  |  Notify Moderator
Some members of the Aliners Owners Club have purchased the Rockwood/Flagstaff A-frames. We welcome all A-frame owners.
They seem to be happy with them but they have only been out for maybe two years.
My Aliner looks like black painted wood underneath. RV floors usually suffer water damage from above, not below. I wouldn't worry about it.
Some Aliner owners have said the wiring and plumbing of the new kid isn't up to par but you sure get a lot for your money.
Be aware that the Rockwood/Flagstaff are much heavier in the tongue than an Aliner in case you tow with a smaller vehicle.
- Soren Kierkegaard
bondebond
Searcy, AR
Posted: 04/20/12 12:19pm Link  |  Print  |  Notify Moderator
I have a 6-year-old PUP with exposed OSB that Weyerhaeuser called Structurwood that shows no signs of succumbing to water, rot, mold, mildew or any other signs of breaking down.
Having had a previous PUP with an OSB floor, but coated as you mention, I was quite leery of this stuff until I researched ad nauseum. With a 25-year warranty, I'm ok with it.
With the previous PUP having the black coating, I actually worried more about any of the new holes I had added or the existing holes from the mfgr not being properly sealed, but encountered no issues at all in the 4 years I had it.
If it is much of a concern but you otherwise like the hardside, get it and add your own protective cover underneath. I wouldn't recommend it, but to that's something you'll have to decide.
This space left intentionally.
2006 Fleetwood Sequoia and mods...one of the tallest highwall pop-ups on the planet after flipping the axle.
ExRocketScientist
Laurel, MD
Posted: 04/23/12 06:13am Link  |  Print  |  Notify Moderator
I had a 1990 Aliner that had rubberized undercoating sprayed on the bottom of the floor. After about 4 years, I attached some 2" thick expanded polystyrene (styrofoam) to the bottom for insulation because I mostly used it in very cold temperatures. One day I was talking to someone at the factory and they asked me about my mods. This led them to the changes you see today.
That 1990 Aliner is owned by a friend now. He lets it sit out in the weather and at one point was off level so water could run in at the bottom of the door. This has resulted in the floor rotting out just inside the door. Still hasn't fixed it yet.
ERS
Apache Adventurer
St. Clair Beach, Ontario, Canada
Posted: 04/24/12 08:55pm Link  |  Print  |  Notify Moderator
Take a look at the original "solid state" (both hard sided side walls and hard sided bed ends) Apaches built from 1971 to 1987 by Vesely Corporation and its dealer network. My wife and I have a 1979 Apache Ramada and it is still very well built and durable, no problems whatsoever. Go to the Apache site - www,apachepopups.net
Mike '63
Bonnie '64
John '88
Katharine '91
James '92
1979 Apache Ramada
2005 Chevy TrailBlazer LT
oldfrat
colorado
Posted: 04/27/12 06:00pm Link  |  Print  |  Notify Moderator
I have a 2005 Aliner that I bought used in 2010. At the time, Aliner and Chelet were the two hard sided brands I was looking for. Either was acceptable, but Chalets had an edge. You should check out both brands.
I can't remember the name of the site, but I found one that searched all of the Craig's List postings in the US and, if you told it what you were looking for, it would e-mail you a link whenever what you were searching for turned up for sale. I needed one with air conditioning, so it took me about 3 months to find one that was in very good condition. I had to drive from CO to OK to get it, but I saved a ton of money over buying a new one and I am truly happy with the one I found. If price is an issue and "pre-owned" is not a huge turn-off for you, you may want to consider going this route.
loganmartin
in the woods
Posted: 04/30/12 10:42am Link  |  Print  |  Notify Moderator
I own a 2012 Flagstaff A-Frame and am very pleased. I had also checked out A-liners and just couldn't justify spending an extra 5K for less features. I suggest anybody interested in A-frame campers to check Forest River Rockwood/Flagstaff models in addition to Aliner and Chalet.
LM
galexander
Omaha,Nebraska
Posted: 04/30/12 03:35pm Link  |  Print  |  Notify Moderator
I have a 2012 Rockwood A128S and have been very happy with it. The price made the differance. With Aliner, everything was an option, with the Rockwood, it all came equipped and ready to go for a lot less money as loganmartin said.
2003 Chevy Silveraldo 2500HD 4x4 SB Ext.Cab 6.0L
2012 Rockwood A128S
