RV.Net Open Roads Forum: Tech Issues: Replace DRL bulb in 2006 GMC 2500HD?
 > Replace DRL bulb in 2006 GMC 2500HD?
Ramblin' Ralph
Central California Coast
Posted: 04/20/12 12:25pm Link  |  Print  |  Notify Moderator
Got everything out OK so that I can grip the 4114 type bulb to remove it from the socket. However, it doesn't want to slide out. Looks like there could be a plastic tab on each side that goes into a groove in bulb plastic base.
Any tips?
Thanks,
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Firestone Air Bags, 125 watt solar
My RV Travels Webpage and Campsite Map
aruba5er
Neenah Wisconsin
Posted: 04/20/12 04:13pm Link  |  Print  |  Notify Moderator
Mine was kinda melted to the plastic surronding the glass.If I remember I just pulled hard. Might be a good idea to put some dielectric on the new one. I'm glad you are fixing it. So many times they just ignore them I think it adds a lot of safety to driving
chipper
Nampa,Id
Posted: 04/21/12 06:08pm Link  |  Print  |  Notify Moderator
you might even have to replace the socket. They get so hot they melt the socket & you cant get the burned out bulb out. There is nothing to hold them in.
gene
Ramblin' Ralph
Posted: 04/22/12 10:09am Link  |  Print  |  Notify Moderator
Thanks for the info.
Maybe that is what has happened. Got too hot and plastic melted. I'll look at it closer.
Ralph
