RV.Net Open Roads Forum: Tow Vehicles: acceptable transmission temperature?
Search only in Tow Vehicles
 > acceptable transmission temperature?
Desert Captain
Tucson
Posted: 04/21/12 07:17pm Link  |  Print  |  Notify Moderator
Just added a Scan Gauge so am now able to monitor trany fluid temps. Saw 204 (highest yet), once today on a 6 mile 6% grade, cruising between 55 and 60, air temp was 95. It came right down once we topped out the grade. Usually runs under 175 but that was one hell of a hill.
NavyDood
NW of DFW
Posted: 04/21/12 08:31pm Link  |  Print  |  Notify Moderator
Just some FYI and not totally relative.
My "weak" 48RE with 165,000 miles on it at the time went from MD to TX taking the northern route through PA, OH, IN MO, AR, and into TX last summer towing 21K combined. I had my Smarty JR. on the 40hp tune and the A/C was on the whole trip. I now have 179,000 miles on my tranny and it still performs like the day I bought the truck over seven years ago.
I snapped this pic of my gauges about an hour out of TX going south on US30 with outside temps reaching 106°F. I had the cruise set at 65mph with the OD on. My tranny temp reading comes from the tranny out line to coolers which is the most real temp you can get. Pan temps would have been lower than the reading you see on the gauge.
- Retired Navy Chief
- Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter
- 06 Pilgrim 30RE2SLF-5 13,300lbs loaded. B&W Companion
ib516
Up here!
Posted: 04/21/12 08:45pm Link  |  Print  |  Notify Moderator
I haven't towed with the Trans temp reading ability programmed into my Scanguage2 yet, but empty, it reads about 165* - 175*. I don't know where it's getting the reading from, but it's wherever the PCM/ECM gets it from.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
45Ricochet
North Idaho
Posted: 04/22/12 10:41am Link  |  Print  |  Notify Moderator
Ahhh that's going south, all down hill
Sorry about the hijack OP, but do you see lower EGT's with the tuner like Madd claims? I need to tap that in this summer.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
NavyDood
NW of DFW
Posted: 04/22/12 08:12pm Link  |  Print  |  Notify Moderator
Haha, true when you look at a map.
In reality the elevation of the airport in Texarkana is 128ft higher than the airport in Little Rock.
milo
4 Corners
Posted: 04/23/12 09:28pm Link  |  Print  |  Notify Moderator
My crappy ole 6.0 will run all day no higher than 185 regardless of terrain
milo
Janet(boss)& Milo 36 & 1/4 yrs 2gether
Retired Educators
Mona Mo 6 yr old Yorkie & (in spirit) our Beagle Buddy
13 F-150 Eco Screw HD 4x4 07 294RLS Cougar TT
Confidence is the feelin you have just before you fully understand the situation
hawkeye-08
Northwest
Posted: 04/23/12 10:01pm Link  |  Print  |  Notify Moderator
This has come up several times for the 6speed GM with the Dexron VI fluid. Here is an answer one member got from GM.
I was also concerned at one pointhowever and contacted GM with the question. There answer was: Good Morning! Thank you for giving me the time to do some research on your concern with the transmission temperature. I have consulted one of our dealers and am happy to inform you that I have the information you’ve requested. The normal operating temperature is between 160°F to 200°F (71°C to 93°C). For towing, the normal operating temperature is between 235°F (113°C) to 260°F (127°C).
