bluefoot
usa
width=480
Converted the "clothes closet" into a pantry. The 01' Lance 845 really lacks storage. Originally had some cardboard boxes in this cabinet and soon discovered that really didn't work.
We purchased a bunch of plastic bins and stacked them on top of each other. That too was too much of hassle. When you need something in one of the lower bins, all bins above it had to be removed. The heavier the bin the more of a pain it was.
There has to be a better way! Took the bins and with this simple easy mod there is a better way!
We left a little bit of room between the bins to hold taller items with the lid off.
last
edited 04/20/12 07:18pm by bluefoot *
View edit history
tilemantim
Santa Rosa,Ca
very nice, where did you get the bins?
daveshan
Durango Colrado
Yep, did the same thing with my 845. That plus the overhead "bunk" are gives pretty good storage.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
bluefoot
usa
Bins are from Walmart. Cheap and sturdy! A bit bigger than a shoe box and fit great in this cabinet. Two more bins are located in the cabinet under the fridge. The bins were less than $2.00 each.
bluefoot
usa
daveshan wrote: Yep, did the same thing with my 845. That plus the overhead "bunk" are gives pretty good storage.
What did you do up there?
Currently working up there. Need some great ideas since I live in it 3-4 days a week.
So far, this is what has been done up there. New mattress (oh it sure was fun getting the old one out)Tried a topper on the orginal mattress but kept whacking da elbows on the ceiling! I'm short and can sit up but couldn't with the topper. Got me to thinking ....what do tall people do?
Installed a gator net going across. Then put quick release buckles on the ends of the gator net for easy access. Things used to slide right off onto the floor driving on mountain roads! We live in the mountains and that was a problem. Got tired of a pile on the floor real fast!
Placed a couple of cube containers from target that have a padded top.
TV mounted on the end of the kitchen cabinet along with a converter box. Would like satelite in the future and need to do more research on that.
Thinking about hanging some bins on the ceiling if that makes sense.
Thanks!
daveshan
Durango Colrado
The overhead bunk I'm talking about is the one over the dinette. Removed all the sleeping gear and there's room for my BBQ, and 9 medium containers from Wally World.
As for the cabover area my friend with an 845 put wire shelving over the windows, haven't got that far with mine yet. Actually I'll probably put bookshelves over mine.
Atchafalaya_man
Lafayette, Louisiana
Turn 12" or 16" wire closet shelves upside down and you have a lip that will keep the plastic shoe boxes from sliding off of them. These are 12" shelves, mounted on a piece of angle-aluminum screwed to the walls.
fullmoonoversalem
Alaska
Great ideas. I don't have picture of it yet, but I saw something on the net once where someone cut the foam insulation into "slices" the depth of the closet placing them along the wall of the closet. The slices were as tall as I wanted in various heights. They then put thin plywood or something rigit between the slices to make shelves. I did that in my house and it worked well. I am asking my DS to take a photo of it. I actually attached the foam with velcro to the side walls of the closet so I didn't have to drill or a hole. This was an odd closet, rather narrow, and tall. It may have been a broom closet at one time. The house is about 225 years old.
2007 Damon Challenger
2005 Saturn Ion
Moli, our sweet Lab Mix
Gus, our insane, sweet Cat
recycler
michigan
cool mod..i think all tc's have space problems my 68 tc had little storage and none in cab over..so I put a full width cabinet on front wall over the east west bed and going to be putting a triangle one on driver side wall in cab over by fridge cabinet...what do tall people do..we hit our heads
1968 franklin 11fk
back to my 93 cummins
