jerem0621
Sequatchie, TN
How about a "I should have bought a bigger truck" sticky?
LOL
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
TomG2
Central Illinois
Fordlover wrote:
You don't have to get the 8,200 pound GVWR to get the 11000 pound tow rating.
I know that you don't "have to", but when you put all the numbers together, tongue weight, passengers, and cargo that most of us carry with us, don't you think you "should" if you are going to tow over 11,000 pounds of camper? I would want the Max payload as well as any other Max options for towing that much, but that is just me.
wilber1
Abbotsford B.C. Canada
As someone said " Ecoboost" is an example of great marketing. Ford isn''t the first to combine direct injection with turbocharging but they are the first to put it in a pickup. It will be interesting to see how it works out for towing because it is a great way to power a vehicle.
"Never trust a man who has not a single redeeming vice" WSC
Fordlover
Spring, Texas
Actually for a 10,000 camper, you need a 3/4 ton.
If I was pulling a 10,000 boat, I'd still consider the Ecoboost. But the reality is that likely less than half of new F-150's will actually pull a trailer with any regularity, even fewer a trailer that will actually 'work' the truck, and even fewer 10,000 pound campers. I think we're safe!
02 Ford Explorer 4.6 V8 4x4, prodigy and equalizer
07 Crossroads Sunset Trail ST19CK
and no payments
milo
4 Corners
There'll be so many stickies ... U'll have a have a sticky just to keep all the stickies in
milo
Janet(boss)& Milo 36 & 1/4 yrs 2gether
Retired Educators
Mona Mo 6 yr old Yorkie & (in spirit) our Beagle Buddy
13 F-150 Eco Screw HD 4x4 07 294RLS Cougar TT
Confidence is the feelin you have just before you fully understand the situation
kmfvfr
Las Vegas
Kevin O. wrote: Engineer9860 wrote: Embarrassing the competition? I'm not seeing that.
The EB a good engine? So far so good. Better than the competition? No.
Each engine offered in all of the 1/2 tonners are doing just what their designers need them to do. I'm figuring you must not have seen this video.
http://www.youtube.com/watch?v=rw1zdFZwlLU
How come they only campare the Ecoboost to the 5.3L Chevy (obvious underdog) and the Dodge that has the giant gap between 1st and 2nd gear? Notice how the Dodge is gaining ground at the end of the run?? Why didn't Ford have all MFG offerings??
2008 Pacific Coachworks Tango 276 RBS
2007 Toyota Tundra TRD 5.7L
Prodigy Brake Controller
Yamaha EF2400iS Generator
Yamaha FJR1300
mister_d
Southeast, MI - hardly qualified to be a
kmfvfr wrote: Kevin O. wrote: Engineer9860 wrote: Embarrassing the competition? I'm not seeing that.
All? Do you realize how many configurations you're asking for?
The ecoboost has proven itself time and time again in EVERY publication known to man. The only real question left is if it will be durable and last over a couple hundred thousand miles.
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
Fordlover
Spring, Texas
kmfvfr wrote: How come they only campare the Ecoboost to the 5.3L Chevy (obvious underdog) and the Dodge that has the giant gap between 1st and 2nd gear? Notice how the Dodge is gaining ground at the end of the run?? Why didn't Ford have all MFG offerings??
What should they have compared the Ecoboost to? Perhaps a Freight train? a golf shoe? Very small rocks?
Have you seen Toyota and Nissan full size sales numbers? A distant 5th and 6th place. At some point you have to stop handing out Trophy's.
kmfvfr
Las Vegas
Fordlover wrote: kmfvfr wrote: How come they only campare the Ecoboost to the 5.3L Chevy (obvious underdog) and the Dodge that has the giant gap between 1st and 2nd gear? Notice how the Dodge is gaining ground at the end of the run?? Why didn't Ford have all MFG offerings??
Perhaps I needed to be more clear so EVERYONE can understand. Compare it to the other MFG offerings with same trim level, 1/2 ton, same drive configuration, all have a box on the rear axle...OK??
I don't give a******about sales numbers either....my point is where are the other trucks in the comparison? Already up the hill waiting?
Ya...F150...Motor Trend Truck of the Year...but everyone agrees on this forum that doesn't mean much because so was the Honda Ridgeline...right??
Fordlover
Spring, Texas
dude... It's a truck. Ease up or you might give yourself a coronary. Anyone who considers the titan competition might want to look up the definition.
