ol Bombero-JC
Jim Cindy wrote:
If you have a big TV, the discs may not be worth the upgrade.
How big a Tow Vehicle is big enough to *not* have the tail wag the dog?.
aruba5er
Neenah Wisconsin
Don't " THINK" discs may not be worth it. You never drove a fiver with them have you? I can lock 4 wheels right now. No drum brake is half as good. Why do they put discs on all cars? They don"t do it because they cost less, they do it to stop in an emergency> Only Rv manufactuers do it to save money. And, if a wheel seal leaks, like one of mine did they don;t throw grease all over the drum. It appears that the grease that leaked flew straight away and never came near the rotors. Can't say that for drums. And NO adjustments ever. Spend the money for disc brakes. You will never by sorry.
golf_bears
Rapid City, SD
I'd like to thank everyone for their input and suggestions. I have a scheduled date in early June to have the system installed. Looking forward to testing the results.
bigdon68
Churchville, Maryland
Just thought I would say a few words. We had our IS System installed (8,000 lb. axles) in June of 2011 and like everyone else -- it is absolutely fantastic. We also had the disc brakes installed.
As we were leaving I found out the also install BIGFOOT LEVELERS. We got those put on in November 2011. Got the latest edition with the Key Fob. Cool
MorRyde has the best customer service you will ever fine. Ben is just fantastic.
Enjoy the install. You won't believe it.
Bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
MY PICTURES
richfaa
Ohio
We had the IS installed on our 2006 3400 Montana two years ago.Price was @ 2500.00 installed. Big difference in ride.
2013 Montana 3402 Big Sky. 08 Ford F-350 6.4L
ford truck guy
Pennsylvania
Bigdon68
What did the Big Foot Levelers run there ??
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
bigdon68
Ford Truck Guy,
The system installed was $4700 and that was with the new wireless panel upgrade and the key fob. Our system was for a 40 ft. 5th wheel so it had (4) 17,000 lb. cylinders.
If I had known when I had the IS System and the disc brakes installed I could probably have negotiated a better deal.
They are well worth it. No more tripod in the front and very little movement.
Enjoy.
Bigdon68
okiejoe
Oklahoma City
I have it and would not have a 5er with out it one other plus is it is very easy to get the axles aligned, great for the tires and improved fuel milage.
ford truck guy
Pennsylvania
Thanks Bigdon68 .... That may be something I want to add next...
shiba88
CT.
Mor-Rydes came on my camper 2011 Eagle. The ride is so much smoother.It even seems to help with the chucking a little bit.
