RV.Net Open Roads Forum: Travel Trailers: black water occasionaly in fresh water faucet
 > black water occasionaly in fresh water faucet
DogTrainer
Tulsa, Oklahoma
Posted: 04/21/12 02:52pm Link  |  Print  |  Notify Moderator
santized last week with bleach. drained and headed out this weekend. occasionaly we get a burst of black or dark water in the toilet or sinks out of frsh water. we do not have a charcoal filter. stock sprinter. is this coming from water pump. water smells good.
2007 Chevy 2500HD 6L Auto 4WD
2006 Keystone 29BHS
Wife and 2 great kids
2 labs
2oldman
Winchester WA
Posted: 04/21/12 03:09pm Link  |  Print  |  Notify Moderator
Must be some debris in the tank.
wtravlr1
Palm Harbor, Florida,
Posted: 04/21/12 03:14pm Link  |  Print  |  Notify Moderator
is it black or green?
DogTrainer
Tulsa, Oklahoma
Posted: 04/21/12 03:15pm Link  |  Print  |  Notify Moderator
looks black, not all the time just occasionally.
CincyGus
Cincinnati
Posted: 04/21/12 03:22pm Link  |  Print  |  Notify Moderator
I'd say your fresh water tank is needing a good cleaning and what you are getting is small pieces of whatever grew in your fresh water tank as it breaks loose. A double dose of bleach and 3/4 full tank and a good drive to stir it up and slosh it around and then drain and repeat until the problem goes away.
When you empty it, run it through your faucets just incase your water lines have the same issue.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
wtravlr1
Posted: 04/21/12 03:27pm Link  |  Print  |  Notify Moderator
yes that sounds like it is it, the only other thing is a bad back flow, but I think its just junk/
DogTrainer
Tulsa, Oklahoma
Posted: 04/21/12 04:50pm Link  |  Print  |  Notify Moderator
what is funny is there is debris. just like tea. no small chunks or floaties. Is it possible the water pump is going bad and is there any oil in that pump?
Old-Biscuit
Across the USA
Posted: 04/21/12 09:04pm Link  |  Print  |  Notify Moderator
Make sure you run that bleach mixture from fresh water tank thru pump thru all faucets/showers (hot/cold sides), toilet, all low point drains and any lines that do not normally have flow thru them (washer lines/outside shower lines etc.).
Lines that are connected to plumbing system but that do not have routine flow can become loaded with bacteria/slime and back feed into system when it has been depressurized/drained and re-pressurized.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
HJGyswyt
Buckley Washington
Posted: 04/21/12 09:59pm Link  |  Print  |  Notify Moderator
Are you absolutely sure you don’t have a water filter built in? On my Forest River Trailer there is a large canister filter just inside the trailer, in the wall behind a removable panel at the head of the bathtub. It’s totally concealed unless you remove four screws and a piece of paneling. Just a thought. Good Luck.
90 Vacationeer 10' T-Camper
1934, 1951, 1973 International's
1998 3/4 4X4 454 Suburban
1996 3/4 4X4 6.5 Turbo Diesel Silverado
Kubota Backhoe
2006 VW TDI Diesel
Prodigy/Reese Dual Cam
02 Wilcat Bunkhouse
MacGregor Sailboat
WW 4 Horse Diagonal Load
Family Website
westend
all over
Posted: 04/21/12 04:56pm Link  |  Print  |  Notify Moderator
The pump casing and impeller is all plastic, even a failed pump won't discolor your water. There is no oil in the pump. It sounds to me like something got introduced into your tank.
You don't need a lot of bleach to clean your system but it does need time. It will work the best if you can let the bleach/water solution to sit in the tank and water lines for more than 12 hrs..
'03 F-250 4x4 CC
