RV.Net Open Roads Forum: Tech Issues: Stanley Waterproof Toolbox as Sealed Battery box...
 > Stanley Waterproof Toolbox as Sealed Battery box...
cruz-in
Southern Maryland
Posted: 04/21/12 03:01pm Link  |  Print  |  Notify Moderator
Hi All,
I have been searching and searching for a sturdy reasonable battery box to add a few extra batteries. I saw mentioned using the Fat MAx Toolboxes. They are waterproof, so already sealed. So what do you all think:
23 Inch Fat Max Tool Box (can be had for $20 even at Walmart)
and
28 inch Fat Max Toolbox
Two Group 27 will just make it into the 23 inch box...
I suspect two group 31s would easily make it into the 28 inch one.
* This post was edited 04/21/12 03:13pm by cruz-in *
pauldub
North of Seattle
Posted: 04/21/12 03:05pm Link  |  Print  |  Notify Moderator
You'll want to vent it unless you are using AGM batts.
RoyB
King George, VA
Posted: 04/21/12 05:01pm Link  |  Print  |  Notify Moderator
great idea thanks...
They may not be as secure and the metal boxes but being out of sight if probably all you need anyway...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
cruz-in
Southern Maryland
Posted: 04/21/12 03:11pm Link  |  Print  |  Notify Moderator
sure...would even vent them with AGMs...
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/21/12 03:19pm Link  |  Print  |  Notify Moderator
X3. You can drill a suitable sized hole in the side and epoxy a PVC pipe of the proper size and sinply put a hose that has been rolled in a circle and tied with a zip tie. The circle is to prevent water from entering while venting the box to the atmosphere. JMHO
charles weidman
boogie_4wheel
SLC, Utah
Posted: 04/21/12 05:08pm Link  |  Print  |  Notify Moderator
I never thought about using a tool box as a battery box. Awesome idea! I have the 28" box in the backend of my truck holding tools now and so far it has been a good one, for the last few months anyway.
Post pictures when finished.
Subscribed!
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Luke Porter
Not on the road :(
Posted: 04/21/12 05:35pm Link  |  Print  |  Notify Moderator
The vent is supposed to be 2" out of both the top and bottom.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
Wherever I happen to park
Posted: 04/21/12 06:16pm Link  |  Print  |  Notify Moderator
IS this box going to be indoors or outdoors.. If it's outdoors you can simply drill a vent hole in the bottom and mount a PVC Flange (With a hole drilled in the side) and an elbow. If inside a hose. (and a flange on the bottom hole too)
My concern is the weight of the battery v/s the strength of the box. How many pounds of lead can it carry... I suspect you may "overload" it.
JimInMich
Mi
Posted: 04/21/12 06:32pm Link  |  Print  |  Notify Moderator
I just bought a new battery box at Menards, it was under $7. This doesnt seem to be an economical way to go. I just dont get it, sorry.
11 Chevy Silverado Ext.Cab Z-71 4x4, 5.3 v8, 3:43 w/locker, Factory tow package, Equal-I-zer 1200#, Curt Class V Receiver
12 Cougar XLite 27RLS ( 960# Tongue, 6740# Gross as loaded)
Just the Wife and I.
CincyGus
Cincinnati
Posted: 04/21/12 06:44pm Link  |  Print  |  Notify Moderator
Same here. I went to Pepboyz and bought a huge battery box for my group29 deepcycle batteryI bought last week for $15. Besides tha fact that I don't thinkit's economical, I'm not too sure a plastic tool box would hold up with the weight of a battery bouncing on it because the bottom may not be moulded with enough structure to support the battery properly. Might work, just seems more expensive than the standard battery box solution.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
