RV.Net Open Roads Forum: Class A Motorhomes: Step support
 > Step support
Janss
Sedona, AZ
Posted: 04/21/12 04:55pm Link  |  Print  |  Notify Moderator
Is there any alternative to this step support that I currently use but find a little cumbersome?
http://www.campingworld.com/shopping/product/stabil-step-jacks/5416
Is there any product perhaps designed like a keyboard bench (but smaller dimensions of course) that is completely adjustable and folds flat? Keyboard bench example:
http://www.amazon.com/World-Tour-Deluxe-Padded-Keyboard/dp/B000BKY8CU/ref=pd_cp_MI_0
I saw from other posts that some carry a bottle jack, but I don't want anything that heavy. Any other kind of jack or jack stand that would be appropriate and easy to store?
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
gokart2
orange park
Posted: 04/21/12 05:37pm Link  |  Print  |  Notify Moderator
I made one for my 3 step system. I made it from 2 X 6 wood. Simply cut 2 pieces appx. 8 - 10 inches long. Then cut one end of one piece on a 45% angle. Lay one piece flat and stand the other piece with the 45% angle on its side down the middle of the flat piece and attach the two with wood screws. You can then slide the completed product under the step for support. The angle end allows for height variation due to different clearence distances. I actually made 2 and put one under each side of the bottom step. (Caution - be sure to remove them from under the lower step before you allow the step to retract!)
FIRE UP
Ramona, CA. USA
Posted: 04/21/12 07:11pm Link  |  Print  |  Notify Moderator
Janss,
While you might find it a bit cumbersome, without a doubt, it's the easiest to use and does the exact job you want it to do. The good part is that depending on how and where you camp, it's adjustable with a wide range. I presently carry two, that camping world version and a taller one that I made myself that works the exact same way. There are sometimes when it just so happens that the front end is a bit higher and, that taller version works better. I also carry those Camping world yellow "Lego" blocks that are stack-a-ble. Together, one or two of those Legos and either one of the step supports and it's a "Rock".
Scott
Scott and Karla
SDFD RETIRED
2011 White Honda CRV EX-L,4WD w/NAV Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
jetenbu
Southeast Texas
Posted: 04/22/12 09:10am Link  |  Print  |  Notify Moderator
Here is a post following yours that would seem to work for you as well.
Step Support
It is adjustable in any location too.
I hope this helps.
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
jojolou
S. E. Michigan & Mission, Texas
Posted: 04/22/12 10:07am Link  |  Print  |  Notify Moderator
In a pinch those little orange leveling blocks work great too.
Lou
2008 Allegro Bay 35 TSB W-25.5
SS Slacker
Lino Lakes, MN
Posted: 04/22/12 10:17am Link  |  Print  |  Notify Moderator
I use the one that you linked from Camping World and find it works great. I know they also make that version that mounts to the bottom of the step and just folds up so you don't have to store it seperately. I can't think of any option that is less cumberson then that. The folding version is no more work then the idea you show from Amazon.
Dan & Tracy
2 kids ages 9 and 11
2003 HR Neptune 36PBD
300 ISB Cummins/5-Speed
cwit
Upstate New York
Posted: 04/22/12 10:40am Link  |  Print  |  Notify Moderator
I used jetenbu's idea about 5 years ago. works great. I bolted a small jack to the steps and leave it right there.
Janss
Sedona, AZ
Posted: 04/22/12 11:27pm Link  |  Print  |  Notify Moderator
Thanks for all your replies.
I did see Dick's post with pictures after I posted mine. It looks like a good idea.
bsinmich
Holland, MI
Posted: 04/23/12 05:47am Link  |  Print  |  Notify Moderator
Why do you need a support under your steps? I was 295# and never used a support. Now I am 235 and still don't use a support. My Kwikee steps are still sound and solid and 9 years old.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
Janss
Sedona, AZ
Posted: 04/23/12 01:21pm Link  |  Print  |  Notify Moderator
To make the steps feels more solid to my partner whose feet are numb and who has poor balance.
 > Step support
