RV.Net Open Roads Forum: Pulling a boat, launching a boat, hmmm.......
 > Pulling a boat, launching a boat, hmmm.......
bsinmich
Holland, MI
Posted: 04/23/12 06:13am Link  |  Print  |  Notify Moderator
You have a long rear overhang there and that will keep the MH level while the boat is going down the ramp. On a very steep ramp you could get into problems hitting the drive unit on the ramp. Been there and done that in Chetek, WI on a very steep ramp.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
NorthernLimits
Michigan
Posted: 04/23/12 06:46am Link  |  Print  |  Notify Moderator
My .02
I have done it several times. With a short boat or a narrow boat it can be done but takes time and practice and a large, empty boat launch.
Trying to launch with something like that during a busy time like we have here for Salmon would result in big tempers.
I switched to a front hitch and wow...what a difference. If I ever go back to a A, I wouldn't even think twice about it. I would get a front hitch right off the bat.
JN_B
Calgary, Alberta
Posted: 04/23/12 07:34am Link  |  Print  |  Notify Moderator
#1. Front hitch
#2. ask/pay someone at the campground (I've launched boats for others before).
#3.http://builtrite.net/doubledeck/index.html
2003 GMC Sierra 1500HD SLT
2010 K-Z Spree 318BHS
johnwalkerpa1
Pennsylvania
Posted: 04/23/12 09:53am Link  |  Print  |  Notify Moderator
harold1946 wrote:
rockhillmanor wrote:
shaneallenhenderson wrote:
I have a 32'class A, but cant see out the back window. I will be pulling a 20' Bayliner to the lake with us. Not sure how this is going to work out. Maybe just pay someone $5 at the lake to launch for me. I dont think I have ever seen anyone launch with a big motorhome.Don't want to have to take my truck as well and pay for gas for 2 vehicles.Any words of wisdom?
Simple, Carry a trailer dolly with you.
This one is rated for 600lbs and I have moved 'well over' the lbs rated with it. They make higher rated dolly's but they are bulkier and weigh more. The smaller ones can be carried inside your boat.
This dolly won't pull a boat over rough terrain, but the parking lots and the boat ramps are flat and the launch is slanted which works in your favor and this dolly works just fine for launching from a flat parking lot to the launch and into the water.
Please do not attempt this with anything larger than a canoe.
X2!!! I had visions of sliding down the launch ramp with my shoes smoking trying to keep the trailer from getting away
Blueflame1
Yes
Posted: 04/23/12 09:56am Link  |  Print  |  Notify Moderator
We used to launch an 18ft Bayliner from our 30 ft Class A Southwind.
The RV had a drivers side door, that I would open to look back/outside and keep the trailer in view. Just practice backing up a bit with a spotter, no need for a front hitch.
The biggest pain was the logistics of finding a campsite, and then getting the boat from the lauch to the campsite.
Once my spotter (wife) was guiding me while I backed up my driveway with the boat behind the RV and the boats propeller went through the garage door....
elkhornsun
Monterey
Posted: 04/25/12 12:23am Link  |  Print  |  Notify Moderator
There are advantages to having a front receiver and using it to launch and retrieve a boat. It is easy to see how far to go into the water to float the boat and not go any farther than is absolutely necessary. Launching at coastal boat ramps and at lakes with low water levels it is not uncommon to run out of concrete for the trailer wheels before the boat is floating - rollers helps a lot as compared to bunks.
I always want to see when the boat lifts off the trailer and I can stop going into the water.
The advantage with a rear hitch entry is that the rear axles are less likely to be submerged in the water with a steep ramp which helps to keep the water out of the brakes and the wheel bearings.
AO_hitech
SF Bay Area
Posted: 04/25/12 05:16pm Link  |  Print  |  Notify Moderator
I found it easy enough with a rear camera. I was using a 27' Class C and a 16' ski boat.
dmatt
Ventura County, CA
Posted: 04/26/12 12:41pm Link  |  Print  |  Notify Moderator
Yeah, me and the wife have been boating for years, just never backed down blind like that.
Heck, how hard can it be.....the way my DW backs down the ramp in the truck I'm SURE she's doing it blind
Don, Jackie and the Boyz
Madison, our loveable Austrailan Shepard
Our new to the clan baby Black Lab, Riley
O'Malley the Alley Cat
Fresno the rescued kitty
Our camping photos
