Cossi
Oklahoma
Had a little camping trip this weekend, just an overnighter. A small amount of waste in the black tank, solid and liquid. How long can I leave it in there without having any issues?
2008 Skyline Nomad
2011 Ford F-150 SuperCrew 4X4 5.0L
Joy
Henderson KY 42420
Put some extra water (at lest 4-5 gals)in the tank along with an enzyme BW treatment and you are good for at least a month, assuming your tank does not have any problems.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
stickdog
29.820224, 81.94542
Joy wrote: Put some extra water (at lest 4-5 gals)in the tank along with an enzyme BW treatment and you are good for at least a month, assuming your tank does not have any problems.
+2
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
navegator
San Diego CA.
Try to dump the waste as soon as posible, unless you want to have a real biohazard area residing in the tank.
If you are not able to dump, then add more water and a digester to brake down the sludge, Home Despot has a product made by Zep Manufacturing, blue in color that is used in ceptic tanks.
This will help dissolve the waste, and with the water, it will prevent the sludge, from becoming the dreaded, brown concrete. Do not leave it in the tank to long, water evaporates, and the sludge will harden.
Hope it helps
Navegator
bikendan
Napa, Cal.
weeks sometimes.
as long as you have water and a tank additive, there's no need to dump until you want to or need to.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
christopherglenn
a little over an hour from Yosemite
I would want the tanks 10-20% full of water before leaving them, more if it is hot. If the water evaporates, that is left tends to be "baked on".
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
tvman44
Southwest Louisiana
As long as you want just so there is some liquid in there so things don't get hard. You don't need any additive unless you just want some.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
CincyGus
Cincinnati
stickdog wrote: Joy wrote: Put some extra water (at lest 4-5 gals)in the tank along with an enzyme BW treatment and you are good for at least a month, assuming your tank does not have any problems.
+2
3x
Just make sure you have plenty of water in there. It sounds like your taking about a minimal amount of waste so the main thing is plenty of water to prevent the waste from hardening. If you are planning on dumping on your way in to a campground and prior to parking at your next campsite, If it were me, I'd put enough water in to get a 1/4 or 1/2 full light on the black tank. Why not if it's all coming out before you camp again. That would give it plenty of water for the waste to disintegrate and make sure nothing dried out. Knowing the size and shape of your tank may help you in deciding how much water you need to make sure you don't have any areas that are not getting water. Most are rectangular tanks with flat bottoms but some are sloped slightly and then you have to ask if you are parking it level so the whole bottom is covered in water. Thats why the 1/4 tank full suggestion.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
C&SL
Western North Dakota
tvman44 wrote: As long as you want just so there is some liquid in there so things don't get hard. You don't need any additive unless you just want some.
X2
2005 Monaco, Signature 525 Hp Cummins
98 Jeep Grand Cherokee
stetwood
Wisconsin
CLefor wrote: tvman44 wrote: As long as you want just so there is some liquid in there so things don't get hard. You don't need any additive unless you just want some.
X2
Best advice
