relliott75
Kansas
So we picked up the TT today, and the dealer setup the Reese DC and it towed like a dream, beautiful! Honestly it felt like a 5k boat! Anyway I got to the camp site, backed in perfect, got the setup started and ooops, can't get TV from TT to level. I had to use the truck jack to get the sway bars off (yes I had the chains loosed already but the sway bars wouldn't budge). So the sway bars are now off, but i was literally lifting the back of my truck damn near off the ground and the TT would not release the TV. Ill mess with it in the morn, but I guess there are worse problems to have. Anyway, here I sit unlevel. If you have secrets or tips on how to get a TT free from a TV ball, pls do share....I've jacked, pulled he truck up and back, jumped on it, banged on it, fussed it then cussed it; to no avail...
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
ifd22
Northern Kentucky
Make sure all of the tongue weight is back on the truck. If the tongue jack is lifting any weight at all the coupler will not let go of the ball.
2002 Outback 28BHS
2009 Tundra
Equilizer WDH
Prodigy BC
Mark and Linda
Smyrna, Tennessee
Did you release the brakes on the tv? Might need to throw a little lube on the ball and components.
michael8rc
Here
Did you open the hitch latch?
1998 Dodge Club Cab 4x4
2010 Wildwood 292FKDS
hmknightnc
Wilmington, NC
1.) Put all the weight on the truck, jack slightly off the ground
2.) unlatch coupler
3.) jack trailer off hitch
SkyPiGG
Southeastern PA
That happened to me for the first time when I dropped the TT off at the storage lot. I had to raise it up a bit to get the coupler off, and then jumped up and down on it a few times to pop the ball loose.
SkyPiGG
2011 Keystone Cougar XLite 26BHS
2011 Silverado LT 1500 Crew Cab 5.3 V8 HD 3.42 (King George)
Fastway E2 10k Hitch
djgarcia
Northern, Ca. , USA
Go to the lumber yard and ask them to cut you 12"x12" block of wood about 12" long. Put it under your trailer jack before you start to lower it. The extra 12 inches of height should easly get your trailer unhooked from your truck. Screw a metal handle to the end of the block to make it easier to move around.
Dick
djgarcia@earthlink.net
mlts22
Austin, Texas
I've had to use a some persuasion to get the W/D bars off on my rig, as well as some jumping action on the back of the pickup to dislodge it. I'd say it is par for the course until the hitch is broken in more.
Bama bluejay
Alabama
DH has the same problem with our new TT. He makes sure it's jacked up high enough and gets on truck and bounces it up and down until it releases. Good Luck.
mtofell1
Oregon
I've had to whack the trailer tongue with a hammer to free things up before (with the trailer firmly dis-weighted off of the hitch). After it's free grease everything up and you should be fine.
