NanciL
Bakersville, NC, USA
It's simple
jack it up and remove the weight distribution bars.
Then jack it back down all the way - Remove the safety pin from the hitch, (if it is stuck, tap it with a hammer). Then make sure the coupler latch is open and jack it back up again. That will relieve the pressure and it should come right off.
I have to do that lots of times
Jack L
Jack & Nanci
pasusan
PA
Here's another discussion on this: Click
This happens often to lots of people. Don't worry - you'll work it out.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
birddogs
midwest
Your TV is putting too much pressure on the safety latch to allow it to release. Remove the WD bars. Then if your TV is in Reverse, put it in Drive. That little bit of forward movement will remove the pressure. If the TV is in Drive when you're stuck, put it in Reverse. Same thing. On my trailer, I don't drop the tongue jack before I switch gears, but I put the latch in the open position. Once the latch is released, I crank coupler up.
xteacher
Newnan, GA
We had the same problem with our last TT. I agree with the advice to either back up or move forward a little (while still hitched, of course!)before trying to get the coupler to release the ball. A few light taps with a hammer also helps, after you've jacked it up. Make sure the chains are still attached, b/c it sometimes comes off in a hurry!
Beth ('57)
DH ('55)
Fur Kids: Potsie (poodle), Maddie (westie mix), and Dempsey (boxer)
2012 Aliner Classic
2010 Nissan Pathfinder
NanciL
Iteachmiddleschool wrote: We had the same problem with our last TT. I agree with the advice to either back up or move forward a little (while still hitched, of course!)before trying to get the coupler to release the ball. A few light taps with a hammer also helps, after you've jacked it up. Make sure the chains are still attached, b/c it sometimes comes off in a hurry!
That is why it is bad to do it your way.
It is much safer and there is no need to back up or pull forward with the TV. See my post above which is the simplest and safest way to get it off when it is stuck
I hope the OP trys it, and I will guarantee that they do it this way from now on
Jack L
lbrjet
Liberty, IN
I chock my wheels and jack up and take my bars off. I then lower until the receiver bar has shows a little space between it and the receiver which relieves the pressure on the ball. Then I usually have to pull forward to move the ball to the front of coupler to be able to undo the latch. Then I have to back up a 1/4 - 1/2 inch to center the ball in the coupler. Then it comes right off. It's a process, but it works every time.
edited 04/22/12 06:48am by lbrjet *
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
relliott75
Kansas
Daylight, calmer kids and a full stomach helped tremendously; I got it unhooked. It's so much easier leveling w/o the TV!
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
Arn
Ottawa Valley, Ontario, Canada
NanciL wrote: It's simple
Jack L
Removing the safety pin works every time. It allows the ball to "float" & center itself under the hitch. Much safer, easier & faster than moving the TV back & forth trying to find the sweet spot.
edited 04/22/12 02:28pm by Arn *
Arn
1958 Me
1963 Her
Sometimes a 2002 granddaughter & soon to be a 2006 granddaughter (then a 2012 granddaughter)
Sometimes a 2004 black lab
2010 Rockwood Ultra-Lite Rear Lounge 2604SS
Life is good my friends, life is good
curveballer98
Hancock, MI
Make sure you release your safety chains absolutely last. after you are uncoupled and after you have chocks in place. sometimes if the ball pops loose... the trailer might want to roll if not secured. don't ask me how i know... but i know, lol. rookie mistake. I always lube my ball before i hook up the trailer..a little bit of grease...i think it's bearing grease that i use. did the trick for us. sometimes, i have to have the wife get into the truck and either nudge it forward or backwards...depending on how the site is situated.
Bucky Badger
Madison, WI
Just curious why one has to use a "truck" jack to get the bars off?
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
