RV.Net Open Roads Forum: Waited WAY too long - Now what
 > Waited WAY too long - Now what
dodge guy
Bartlett IL
Posted: 04/22/12 11:51am Link  |  Print  |  Notify Moderator
I use brake clean to remove tar. works great and won`t harm the finish.
And don`t you like how the sign says "fresh oil" if it was oil it wouldn`t dry to the point you couldn`t wipe it off!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
mudmaker
Iowa
Posted: 04/22/12 12:00pm Link  |  Print  |  Notify Moderator
3M general purpose adhesive remover.
Glen and Loretta
Marc, Jake, and Kirsten
Keystone Cougar 326MKS
2013 GMC Terrain
12 Silverado 3500 SRW quad 6.6 Dmax
03 Dodge 3500 DRW quad 5.9 cummins
Yamaha EF2400is gen
bucky
Eastern Shore of MD
Posted: 04/23/12 04:32am Link  |  Print  |  Notify Moderator
Fingernails can pop them off also, then some of the above products to remove the residue. Cuts down on the smear amount.
99 K3500 DUALLY 07 JAYCO 345 BHS
theoakman
Hereford, AZ, USA
Posted: 04/23/12 04:19pm Link  |  Print  |  Notify Moderator
For years I've heard that Coca Cola will work well. Have never tried it, but would certainly be less expensive than many other cleaners....
Cya l8r,
the oakman
funny, I don't remember being absent minded
wbrown62
Posted: 04/23/12 07:39pm Link  |  Print  |  Notify Moderator
Another vote for WD-40
2011 Keystone Bullet 246RBS
2000 Chevrolet Silverado
bogie514
Delaware, Ohio
Posted: 04/24/12 11:01am Link  |  Print  |  Notify Moderator
I too used WD-40 to effectively remove tar from my trailer and TV.
2007 Max Lite 23RS
2008 Silverado Crew Cab 4wd
Equil-I-zer hitch, Prodigy BC, McKesh Mirrors
UsualSuspect
Saugus, CA
Posted: 04/24/12 11:13am Link  |  Print  |  Notify Moderator
I use Spray and Wash. May have to let it set on there for a few minutes.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC
2011 Toyota Tundra
Gone but not forgotten, 2008 Jayco 299 RLS
RoyB
King George, VA
Posted: 04/24/12 01:33pm Link  |  Print  |  Notify Moderator
I always use WD-40 first on anything like this. mainly because I always have a can of it sitting close by. It seems to work on anything you try using it on.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
bobcouch
Southeast Texas
Posted: 04/24/12 02:00pm Link  |  Print  |  Notify Moderator
Thanks for all the great suggestions.
After posting, I remembered my father using fresh motor oil to clean up after working with old grease and dirt coated equipment.
I used a 1:1 oil and gasoline mixture to remove the tar then came back with the bug and tar remover and a fresh wax. Looks good as new.
Bob and Honey Couch
Miniature dachshunds Tinker and Dusty
2008 Keystone Everest
2007 Dodge MegaCab w/ 5.9 Cummins
http://boggythicket.blogspot.com/
