RV.Net Open Roads Forum: Running lights left on at night
 > Running lights left on at night
Page of 5
MegaJohn
NW Geogia
Posted: 04/26/12 07:21am Link  |  Print  |  Notify Moderator
I constructed a 7-pin plug-in adapter using a mating 7-pin connector from AutoZone and an inline fuse. I trimmed the excess plastic from the connector... connected the fuse holder’s leads to the correct pins… the fuse hangs out the back.
I connect the adapter when I want the running lights on, but I like the idea of putting in a fused switch. I will probably find the parts in my left-over box and do something like that in the future.
I think the lights are cool... others may not. I have left them on all night when I've forgotten to remove the adapter, but I try to disconnect it before bed... and turn off the rope lights.
If camping at a "dark" campground... there's usually no power hookup. In these cases, there's no need to waste my battery power lighting up my rig... and apparently annoying others.
I have photos of the construction of my adapter... if someone is interested, I'll post them to this thread.
Happy Camping!
John.
Stock 2006 Dodge Ram 3500 MegaCab, 5.9L Cummins, Automatic, 2WD, Dually
- 30' 2006 Pilgrim Interntional travel trailer, dry weight ~7k pounds, GVWR ~9k pounds
- Husky weight distributing hitch, friction anti-sway control, electronic brake controller
BarneyS
S.E. Lower Michigan
Posted: 04/26/12 07:44am Link  |  Print  |  Notify Moderator
Thread closed.
Page of 5
