RV.Net Open Roads Forum: How to tell the age of a truck camper.
 > How to tell the age of a truck camper.
Canadian Campers
Sudbury, Ontario, Canada
Posted: 04/22/12 01:24pm Link  |  Print  |  Notify Moderator
My son is looking at buying a pop-up truck camper. The seller states that the camper is a certain year, but based on pictures on the Internet, the camper appears to be newer than stated. (Which is a bonus for my son).
Is there any way to actually tell the date of the camper so we know for sure?
Thanks for any and all answers! Appreciated!
D&S
2001 Dodge Ram 2500 Cummins Diesel
21' Gulfstream Ameri-Lite
midnightsadie
ohio
Posted: 04/22/12 01:31pm Link  |  Print  |  Notify Moderator
some place ,behind a door there should be a manufactures sticker dated what it has and the built date , also look on the title. get the ser number call the builder.
firemedic08
North Central PA
Posted: 05/02/12 05:24pm Link  |  Print  |  Notify Moderator
Some times thre is a tag under the entry door sill plate.
Donnie
1994 Chevy 2500 Extended cab
1980 sunline,
kerry4951
East Central Pennsylvania
Posted: 04/22/12 01:33pm Link  |  Print  |  Notify Moderator
There is usually a Vin tag on the unit that states its serial number, weight, and date of manufacturer. Should be attached somewhere visible.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
AnEv942
CA
Posted: 04/22/12 01:41pm Link  |  Print  |  Notify Moderator
If the original sticker or plate was removed you might look at some of the appliance tags-sometimes dated. Could be out side, in a cabinet, on the cieling...
Not all states require title, we dont have one on ours.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
garryk6
Kodiak, AK
Posted: 04/22/12 03:26pm Link  |  Print  |  Notify Moderator
Since Alaska does not require titles, the PO said my Avion was a 1969 because he had some literature (wire diagrams etc) that was dated 1969. But I had been researching Avions for a good while before I found this one. I knew if it was a 1969, it would have the lucite windows vice the Jalousie windows that it has. But i had to call Cayo repair to see how close I had guessed. I was close. They are calling mine a 1966... You can use those types of things as clues when there are no papers, as well as looking for dates on the appliances as previously mentioned. Sometimes other things will have dates too, like a tag on the water tank, or the fixtures on the sink etc. Just ideas...
Good Luck,
Garry in Kodiak
Garry K
Wife + 4 kids
Retired Military Family.... Alway's on the move....
2002 F350 CCSB 5.4 6spd 4x4 in AK
1966 Avion C-10 Truck Camper
snowcrustracer
New England
Posted: 05/02/12 06:06pm Link  |  Print  |  Notify Moderator
On my Four Wheel Camper there is a serial # written down under the carpeting near the lift panel above the bed rail.
You can call the manufacture to see if there is a tag or serial # hidden somewhere on the camper.
snow
2000 Toyota Tundra & 2007 FWC Eagle
