RV.Net Open Roads Forum: Truck Campers: didn't want to ask this but...
 > didn't want to ask this but...
campn4walleye
Central WI
Posted: 04/22/12 02:55pm Link  |  Print  |  Notify Moderator
where the ^#(( is the water pump and the bypass valve on an Adventurer? Keep in mind that this is the first time of use.
We've searched EVERYWHERE, took out drawers, opened every storage hole, found nothing. We can hear it but nothing is coming out of the faucets. We filled water in the fresh tank. Whereever it is, it must be horrible to reach. We have a wet bath and there is no access panel to anything. Goodness knows what will happen if there's a leak.
Poor DH is so frustrated. He figured it would be easy like our 5er. HA!
Please assist...again. Just one more example of how bad our dealer was. They pointed at 2 valves under the TC and said "those are your bypass valves." NOT!
So much for our maiden voyage...we'll probably end up going to the dealer instead.
You can't see me...but this is my VERY UNHAPPY FACE.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
James'
Ventura, CA
Posted: 04/22/12 02:58pm Link  |  Print  |  Notify Moderator
From another fourm:
"I beleive the water pump on your unit is located in the storage compartment or shower compartment located in front of the entry step in back of the water heater mounted on the wall...."
2006 Chevrolet 3500 HD 4X4 dually, crew cab.
6.6 diesel, Allison trans. Air bags.
2011 Lance 992 duel pop-out, 2200 gen, 135 watt solar panal, Yakima skybox.
James'
Ventura, CA
Posted: 04/22/12 03:07pm Link  |  Print  |  Notify Moderator
12 volt water pump: The water should always be primed to the tap first by the hand pump once the water is at the tap the 12 volt pump can then be used. This will prolong the life of the 12 volt pump considerably.
DiscoChicken
Lawrenceville, GA
Posted: 04/22/12 03:32pm Link  |  Print  |  Notify Moderator
Bypass Valve is under the step up to the bed in my 86sbs.
You'll need a box end driver to get the screws out of the step.
Adventurer/Ford
campn4walleye
Central WI
Posted: 04/22/12 03:43pm Link  |  Print  |  Notify Moderator
no screws that we can see and the fuse panel is in the front of it.
campn4walleye
Central WI
Posted: 04/22/12 04:11pm Link  |  Print  |  Notify Moderator
how does one prime it by hand?
I'm so confused. DH is now thinking that it's a pump issue. He's pretty handy on all things like this.
Photomike
Southern Alberta or where the camper is parked!
Posted: 04/22/12 04:31pm Link  |  Print  |  Notify Moderator
Never did it this way, don't have a hand pump and in fact my pump has run dry (not recommended and don't ask why) for a couple of hours. I then added water to the tank and it started to pump right away.
As for the original post good luck locating it, wish I could help.
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Homemade Cargo Trailer for hauling supplies
Advanced Elements Kayaks
Border Collie Guard Dog
ejfranz
Maple Ridge, BC, Canada
Posted: 04/22/12 05:48pm Link  |  Print  |  Notify Moderator
In our 90FWS the water pump is in the step up to the overhang. The screws that hold the top down are hidden in the carpet.
I fill the hot water tank with the city water connector, other wise the pump runs a long time transferring the water over.
06 Chevy Silverado 3500 Crewcab SRW 4WD - Allison 6 speed & Duramax LBZ.
Upgrades: BD diesel exhaust manifold, Edge Evolution, Timbrens & KYB Monomax.
Camper: 2005 Adventurer 90FWS - Electric jacks, LEDs, 6V batteries, roof rack, ladder & awning.
billtex
RI
Posted: 04/22/12 05:56pm Link  |  Print  |  Notify Moderator
Which model do you have?
(Fill out your sig...)
Check adjacent to water heater...
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
DiscoChicken
Lawrenceville, GA
Posted: 04/22/12 06:06pm Link  |  Print  |  Notify Moderator
It is there. You might have to dig in the carpet for the screws. It is behind the fuse panel.
