dtm222
Northern NJ
Would it be better to make sure the cable is RG6 since you may use that 25' length. It should carry the signal better than the older RG58.
yloshrk
Louisiana
Actually not a dumb question, I have been at a couple of state parks that had the cable.
Tom_M
New Hope, MN
dtm222 wrote: Would it be better to make sure the cable is RG6 since you may use that 25' length. It should carry the signal better than the older RG58.
RG-58 is 50 ohm and is typically used for communication devices (CB, 2-way radio, and ham). I should not be used for TV.
RG-59 is 75 ohm which is used for TV.
A good source for most any kind of cable is Monoprice.com
Tom
2005 Born Free 24RB
MALE*RN*777
Western MD, USA
As I see some pictures posted above I would also go with the 25ft along with the splitter and a couple of shorter cables. You never know when someone else wants to watch something else.
03 Ford F150 XLT
Good-bye old friend --- 01 Coleman Sante Fe Pop-up
Hello new friend --- 09 KZ Coyote 23CR Hybrid
Me ,The Wife ,The Boy ,Girl 1 ,Girl 2
We are Blessed.
SteveRuff
Bacliff, Texas, USA
and with my old fingers I like the kind that just push on instead of the kind that screws. Screwing might make for a better connection but it is tough to unscrew the next day to get ready to leave. I have never had a problem with my push on kind.
Both retired. Travel with Nicky the Schnoodle. Son graduated and is teaching high school math. We still love our 2006 34' Allegro Bay XB and have 40,000+ miles on her.
Kit Carson
Northwest Louisiana
I agree with the push on adapter ends. Also I prefer RG-6 coax. Just leave it plugged into motorhome.
KIT CARSON
GOOD SAM LIFE MEMBER
USAF VETERAN
ARS: KE5VLE
NORTHWEST LOUISIANA
beermanjoe
Pa
Although RG-6 cable is the better of the two. There is less than a db of loss difference between the two at 25`.
green2rvn
Lynnwood, Washington
We are totally new and went on really our first trip and there was cable hook up. The used rv we purchased had the cables, but the tv only would show the channel number on screen, but no reception of the channel. Our rig is a 2009, that made me wonder if the switch box is outdated and if the newer ones are digital? Or if we just don't know what we are doing which is likely the case one way or the other.
2009 Four Winds Siesta 21BC B+
Dave n Holly
Lansing IL
green2rvn wrote: We are totally new and went on really our first trip and there was cable hook up. The used rv we purchased had the cables, but the tv only would show the channel number on screen, but no reception of the channel. Our rig is a 2009, that made me wonder if the switch box is outdated and if the newer ones are digital? Or if we just don't know what we are doing which is likely the case one way or the other.
Just a shot, but I had the same thing happen in my brand new coach and they forgot to tell me to turn off the power amp on the air antenna when using cable.... that button is located in a very "hemmed in" area that you can't even see in my coach, so I didnt even know there was such a button,
If that amp is on you wont get any cable.....At least not in my Coach, I shut the amp off cable worked fine!
2009 Coachman Freedom Express 31
2009 Ford E450 Super Duty Triton V-10
Quadra Bigfoot Auto Levelers
CincyGus
Cincinnati
Dave n Holly wrote: green2rvn wrote: We are totally new and went on really our first trip and there was cable hook up. The used rv we purchased had the cables, but the tv only would show the channel number on screen, but no reception of the channel. Our rig is a 2009, that made me wonder if the switch box is outdated and if the newer ones are digital? Or if we just don't know what we are doing which is likely the case one way or the other.
Correct! I learn this here but have not camped where I had cable to test. The little plate that generally has a 12v female receptacle in it and the cable coming out of your TV plugs into, as a very tiny pushbutton switch that you need to press to turn the amp off. Once you do, your TV should be good for cable hookup.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
