RV.Net Open Roads Forum: Television - Do You Need a Special One For an RV?
 > Television - Do You Need a Special One For an RV?
rodsnreels
West
Posted: 04/23/12 07:16am Link  |  Print  |  Notify Moderator
Thanks everyone!
'11 F350 4x4 Longbed, SWD, 6.7L diesel
2005 Glendale Titanium 25E30
'98 Crestliner 1850 Sportfish
mlts22
Austin, Texas
Posted: 04/23/12 08:57am Link  |  Print  |  Notify Moderator
The only real thing I'd look for with a TV for the RV would be the ability to run on 12 volts. That, and as said above the ability to have a ton of different inputs.
I do recommend taking it off a rack and storing it with the screen protected when storing the RV off-season. This way, if the rig gets broken into, the TVs can vanish without a tweaker tearing the arm off the RV's wall. It is one thing to lose a $200 TV. It is a lot worse to have to deal with that, as well as trying to fix damaged studs and such.
aruba5er
Neenah Wisconsin
Posted: 04/24/12 08:06am Link  |  Print  |  Notify Moderator
They must be special. The Maker of your RV charges between $800 and 1000 for them, so they must be of superior quality. B.S. I bought a 26" Visio from walmart. 3 years and counting
ExRocketScientist
Laurel, MD
Posted: 04/24/12 08:42am Link  |  Print  |  Notify Moderator
I have had problems with consumer grade electronics in the trailer. So when I went to get a TV for the new TT, I shopped a little more carefully. I didn't want the expense (and space) of installing an inverter in this trailer, so I looked for something 12 volt with a low amp draw. Conformal coating was also desired as it would hold up to the less than ideal environment in the TT.
I ended up with a 24" LED model that runs off of 12 volts. The TT came with a stero system and DVD player that is already 12 volts. The combination seems to be pretty good.
You will want to remove the TV during the winter if the trailer sits on a storage lot, otherwise, eventually someone may remove it for you (but not be willing to put it back in the spring).
ERS
jtovosr
Naples Florida
Posted: 04/24/12 04:49pm Link  |  Print  |  Notify Moderator
There is a nice article in May, 2012 MotorHome Magazine that uses a mount specifically made for RV's.
