kingrick5
Canada
There are two locks on the door of my kodiak. One on the handle the other like a dead bolt. The dead bolt is jammed and will not budge. Help Help!!!
drenjoey
Gray, Maine
If it was me, I would try to get in by the bed ends and see if I can unlock it from inside.
Dre
jconnally
Trussville, Al
Perhaps there a bind in the deadbolt due to the frame being supported uneven. Raise or lower your trailer tongue to see if you can change the angle and try again.
2008 Chevy 3500 SRW Duramax/Allison
2011 Sierra 345RET 38'10"
(2) Honda EU2000
kingrick5
Canada
Tried that Dre. There is a little red lever inside and it wouldn't budge. Had my wife jiggle the key on the outside while i tried the lever on the inside....no go. Next???
Mr. Redlegs
Here
I'd get plenty of WD40 into the key hole and let it sit for a while. You might also try pushing in on the door. My guess though is that it needs to be lubricated.
Our New Rig!
2009 Ford F150 King Ranch SCrew
2012 Rockwood Roo 23SS
Equalizer WDH
R.I.P.
(Totaled in an accident on the way home from a wonderful weekend of camping, 9/25/2011)
2004 Ford F150 Lariat SCrew
2008 KZ Coyote 23CFK
Equalizer WDH
Prodigy Brake
mobilefleet
on the road
if it continues to be stubborn just bust it with a screwdriver and hammer from the outside. I lost the keys to mine, and since a locksmith call is $75 to $100 I just hammered it out and turned it with screwdriver. A whole new lockset with new keys is only 35 bucks at a dealer, and 25 bucks on ebay.
kingrick5
Canada
Thanks guys.
I'll put the wd40 to it tonite and try it again in the morn.
Rick
bikendan
Napa, Cal.
happened to us. went in through the bunk end and unscrewed the latch assembly from inside.
was able get the whole thing lubed then.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
dadmomh
Jackson, TN
On the WD-40....unless you've already done it, suggest you don't. A locksmith at my old office told us that was the worst thing to use since it will freeze. Make a Lowe's or HD run and get some powdered graphite especially for locks or maybe they will have the spray especially for locks. If you've already done it, good luck. Hope it works.
2013 Rockwood Ultra Lite 2604
2003 Ford F-150 with Blue Ox 1000 & Prodigy
5 doggies - We support Adopt/Rescue
Sam, you were the best!
Foxy is our new camping buddy
LadyRVer
I have to pull the door to me (inside) and then the red handle will lock, maybe this would work to release it? I'm with the other posters, lubricate if you can. Also if you have ERS, would they be able to help? Just a thought.
