bobnshellz
Butte Alaska
We just bought a 1987 Fleetwood Jamboree, she is a gem and has been well maintained. We have 2 fuel tanks one original and one we believe is after market. The back (original) tank we believe has an in-tank fuel pump and we do not think it is working. Can we draw fuel through the in-tank pump with an electric frame mounted electrical pump?
FuzzyKnight
Santee, Ca
Why don't you just drop the tank and replace the pump???
Fuzzy and Mary
1994 Pace Arrow 33
1928 Model A
1953 Ford Club Coupe
1963 1/2 Falcon Ranchero Original factory V8 4 spd
1963 Fairlane SportsCoupe
1965 Honda SuperHawk
bobnshellz
Butte Alaska
We are going to once my husband can get it to his shop. It is about 10 miles away and he wants to just quick fix it to get it moved.
bobnshellz
Butte Alaska
mowermech
Billings, MT
I have a 1995 Class C Ford E350/460 based coach, also with fuel delivery problems (described to me by a knowledgeable mechanic as "Hot Fuel Syndrome").
Why not drop the tank and replace the pump?
Well...
1. It is expensive, labor and parts both.
2. There is no guarantee that replacing the in-tank pump will solve the problem, but adding a high pressure inline pump probably will. Maybe. So "they" say.
3. Doing it myself is not an option. I simply don't want to!
Ford, in their infinite wisdom, built a vehicle for the motorhome market that builds up too much heat underneath, and didn't provide adequate ventilation. the engine and transmission do not overheat, but everything else does.
At least that is what the "experts" tell me.
I think the real "fix" will be to trade it in on a NON-Ford diesel pusher!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
OnaQuest
Old enough to be a
mowermech wrote: I have a 1995 Class C Ford E350/460 based coach, also with fuel delivery problems (described to me by a knowledgeable mechanic as "Hot Fuel Syndrome").
Well...
Thanks for my daily chuckle.. Way to go.....this is the first time I've seen the old "buy a DP" fix suggested in a long time. And still very helpful, I might add...
bobnshellz
Butte Alaska
Well it worked! Put the in-line fuel pump direct and she started right up. Can get her to the shop and then give her a real go-over. It's summer in Alaska and I can not wait to go camping!
vegasfoodguy
Reno Nv
Well...
This is the first time I've heard "Too much heat underneath the motorhome", The fuel pump is cooled by the fuel in the tank, If the fuel gets too low too often, The fuel pump is toast. I know there were some issues with early fuel pumps, when they were replaced, no more issues. (usually)
Monaco Diplomat, Cummins, 38a
Toad Grand Cherokee, Brake Buddy.
robatthelake
Vancouver Island
I would be looking for an external Pump to replace the in tank model. Holley makes a great one that should work if the Rig has a Carburator. Holley Red!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
dale007
va
Yes mine old one did same thing put pump on near tank drove 400 miles 460 is a good eng
