RV.Net Open Roads Forum: How to judge how much to "gear down " on mountain roads
 > How to judge how much to "gear down " on mountain roads
s79vette
Twin Lake.Mi.USA
Posted: 04/22/12 09:20pm Link  |  Print  |  Notify Moderator
most truckers go down one gear lower than going up and it's always worked for me
2003 Gulfstream Ultra Supreme Ford V10 2004 Jeep Liberty, Blue Ox, Brake Buddy
Online with Inspiron
A member of http://www.gsowners.com
BobGed
Carson City, NV
Posted: 04/22/12 10:18pm Link  |  Print  |  Notify Moderator
Jowalk911 wrote:
BobGed, Thank you. most helpful and we're coming your way. Leaving Las Cruces, NM on May 11 and heading to Carson City, by way of Grand Canyon. Anything particular to look out for, if you know the route?
Joe Walker
Joe, If you're going to the Grand Canyon then I'm going to assume you'll be heading north through Las Vegas to get to Carson City. If that's the case then I would recommend Hwy 95 up to Fallon and then Hwy 50 over to Carson City. This is a very easy drive with no major climbs. Now the only problem with this route is that it is about 450 miles from Vegas to Carson City with very few RV parks. When we take this route we just drive straight through, however The Ramada Inn in Tonopah (about 1/2 way) does have some RV parking in the back with full hookups. Definitely nothing fancy, but I believe it's only about $19 per night. Phone number is (775) 482-9777.
Let me know if you need any info for parks around the Carson City area, or for something additional depending on where you're heading from here.
-Bob
2009 Tiffin Phaeton 40QSH
2011 Jeep Wrangler Sahara
slickest1
canada
Posted: 04/22/12 10:21pm Link  |  Print  |  Notify Moderator
Start down a hill going slow and the trick is to find the gear that will hold it back without having to ride the brakes. Like I say start down in a lower gear and if it is too low you can upshift. Easier than trying to slow down and get into a lower gear when your brakes are overheated. After doing this a few times you will get the feel of it and be more confident in choosing the right gear. Good luck.
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
Jowalk911
On The Road
Posted: 04/23/12 02:15pm Link  |  Print  |  Notify Moderator
thanks to everyone for your help.
Joe & DeeDee
rvjer
Palmdale, CA.
Posted: 04/23/12 09:16pm Link  |  Print  |  Notify Moderator
Joe,
Here is what I have taught commercial & RV drivers for many years. As you start down a hill downshift one gear, if your speed increases five miles an hour in less then five seconds, use the brakes "firmly" to slow enough to go to the next lower gear. repeat these steps as low as you need to. Make sure you do not "ride" the brakes, just hit them enough to slow you down to a shift point and then take your foot all the way off. This way you should not heat up the brakes and be able to stay safely in control.
Jerry
2003 35-E Bounder
2006 Saturn Vue FWD toad
BigRabbitMan
Dixon, CA
Posted: 04/23/12 10:44pm Link  |  Print  |  Notify Moderator
rvjer wrote:
Joe,
This is the way to do it.
BigRabbitMan & DiamondGal
Diatomaceous Earth for health
76 FMC #1046, Gas Pusher W/Chrysler 440-I
Edelbrock MPI fuel injection, Allison 545
Toad: Red '87 4x4 Subaru Brat, '95 Honda Accord
DataStorm Satellite internet / I am here-click to see
bsinmich
Holland, MI
Posted: 04/24/12 05:20am Link  |  Print  |  Notify Moderator
If your brake fluid hasn't been changed in the last 2 years this is the perfect time for a flushing out. The moisture that collects in brake fluid will allow it to boil at much lower temperatures than fresh brake fluid. The boiling of the moisture will mean zero braking when you need it.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
