RV.Net Open Roads Forum: TV reception woes -Winegard VS model switch
 > TV reception woes -Winegard VS model switch
CatandJim
Tulsa, as in Oklahoma
Posted: 04/22/12 09:15pm Link  |  Print  |  Notify Moderator
enblethen wrote:
You said the TV works part of the time. Have you tried different inputs to see if it is isolated to the antenna?
If it is isolated to the antenna it sounds like a bad coaxial connection.
The TV worked part of the time (not well, but we were able to get a local channel or two) last camping season. We've yet to get a picture on it this year.
I really appreciate everyone's ideas. My husband is hoping to be able to fix this himself..well with some help from y'all, that is.
Cat
(Jim just reads the forum once in a while)
Our toys:
2003 Damon Ultrasport 3873
(picture on profile)
Boat = ProCraft Fish & Ski
Working our way toward retirement...wishing it was soon.
dougrainer
Carrolton, Texas
Posted: 04/23/12 06:10am Link  |  Print  |  Notify Moderator
Winegard Video selector switches do NOT have an internal fuse like the regular Winegard booster wall plate. When you have a SHORT in the COAX cable from the Winegard to the Roof top antenna, that light will go out (shutting it OFF). So, you have a SHORTED coax, most likely corrosion at the roof top area, Doug
enblethen
Moses Lake, WA
Posted: 04/23/12 07:14am Link  |  Print  |  Notify Moderator
Has he checked for 12 volts DC at the antenna head?
Diconnect the coaxial cable from antenna,Connect voltmeter to coaxial cable, connect positive lead to coaxial center and the negative lead to the outside. (Yes, it doesn't really matter on DC). The voltage reading should be the same as coming out of video switch. This may show whether there is a real bad connection.
Make sure the switch is on! See if LED stays lit.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Lobstah
Northeast
Posted: 04/23/12 10:55am Link  |  Print  |  Notify Moderator
I think you meant to say "...it DOES really matter on DC..."
This is the reason I went with the Jack antenna. Came with a new plug-in amp. Never did find the Winegaurd one, but for $50, all the problems went away.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
enblethen
Moses Lake, WA
Posted: 04/23/12 11:38am Link  |  Print  |  Notify Moderator
The digital meter on DC doesn't care about polarity, yes the antenna system does.
Lobstah
Northeast
Posted: 04/23/12 03:34pm Link  |  Print  |  Notify Moderator
Well...now that I read that more carefully, I stand completely corrected. I have a few digital meters, but was thinking of my old analog meter, which does care
Thanks for making me think a bit, enblethen
Jim
CatandJim
Posted: 04/23/12 05:30pm Link  |  Print  |  Notify Moderator
All of you have helped us think... thank you!
Hopefully my husband can figure it out now.
CatandJim
Posted: 04/29/12 10:58am Link  |  Print  |  Notify Moderator
It's fixed!
After much troubleshooting, discussing (& a bit of cussing), testing, and retesting he figured out the digital converter box was bad.
Thanks again everyone for your suggestions, he tried them all!
Cat & Jim
badger47
Jonesboro, GA
Posted: 04/23/12 07:45pm Link  |  Print  |  Notify Moderator
Enblethen has it. Antenna boost power gets there via the coax. Likely that faded half quality picture last season was w/o any amplification. Buy or borrow 50 ft of coax, connect to antenna, then back into video selector. If you have a good picture its just the cable.
Winnebago Vista 35F
Equinox behind
CatandJim
Posted: 04/24/12 06:48am Link  |  Print  |  Notify Moderator
Thanks "badger" my husband was trying to find a longer coax in the garage last night. You know... it's one of those "it's around here somewhere" items that may or may not actually be around any more.
ha ha!
I think he has the same idea in mind.
