RV.Net Open Roads Forum: Travel Trailers: Sportsmen S242SB
 > Sportsmen S242SB
atvaholic
Niagara Falls
Posted: 04/22/12 05:12pm Link  |  Print  |  Notify Moderator
Hi, we were at the dealer today and saw a KZ sportsman with the bunks, and a floorplan that is perfect for us.
It's dry weight is 4600 and my TV is rated for 6500, so even with propane tanks, battery and our gear I should be well below the limit.
I know very little about these except the floorplan and the price is right! Can someone tell me their experiences?
APT
SE Michigan
Posted: 04/23/12 05:44am Link  |  Print  |  Notify Moderator
You will be closer to 5500 pounds ready to camp, which could put you TV over one of its limits (like GVWR, tongue weight or GCWR) being well under the tow rating. What is the TV?
2012 VW Passat TDI
atvaholic
Niagara Falls
Posted: 04/23/12 07:17am Link  |  Print  |  Notify Moderator
Hello,
It is a toyota tacoma double cab. Payload is listed at 1150.
CamperWill
Massachusetts
Posted: 04/23/12 07:26am Link  |  Print  |  Notify Moderator
The Sportsmen S242SBH has a gross weight of 6000lbs, 13% of that leaves you with a tongue weight of 780.
1150(payload) - 780(tongue weight) = 370lbs for cargo and passengers.
2007 GMC Envoy 4.2L I6
2012 KZ Sportsmen S242SBH
Prodigy P3 & Reese Dual Cam
CamperWill
Massachusetts
Posted: 04/23/12 06:22am Link  |  Print  |  Notify Moderator
The S242SBH is a great camper.
What is the payload rating on the TV? This is generally the first weight that will be exceeded.
atvaholic
Niagara Falls
Posted: 04/23/12 07:40am Link  |  Print  |  Notify Moderator
Hi Will, my apologies, im missing something here.
When reading some posts on the forum, I was told to look at the "yellow sticker" weight, then add some for the additional gear. I was not aware we needed to use the gross weight.
CamperWill
Massachusetts
Posted: 04/23/12 07:52am Link  |  Print  |  Notify Moderator
You do not need to use the gross weight.
You could use 5500 if that's what you will load it up to, in which case your payload would be 435lbs.
 > Sportsmen S242SB
