maryvillept
Jackson, MO
Anyone know how to get it back to shining? It's all the way around the lower portion of my camper and is dull from oxidation I'm assuming.
2012 Chevy 3500hd crew cab short bed. 6.0 L, 4x4
16k Reese slider hitch
2007 Forest River Salem 38' toy hauler
mmccwill
Arizona
Lowes sells a polish for the Diamond Plate tool boxes -- Bill Willard
twodog
arizona
Previous years I've used Turtlewax Rubbing and Polishing compounds. The results were OK. This season, I used Mothers Mag and Aluminum Polish. The results were much, much better. Mothers will remove all the swirl marks on the surface. It left my trim with a mirror finish. Very pleased. The fine print says it is not recommended for chrome, so I was a little apprehensive at first. After moderate elbow grease, the finish has a brilliant reflection. This is not the only product that will work as others will attest. But Mothers worked for me.
Good luck...........
2dog
17' nash,pv,axleflip,hd sus w/shocks, yamaha gensets
t4r, arb goodies
bstark
Ontario, Canada
The trick is to seal the surface after polishing and brightening it. Also don't ever take your trailer through a Blue Beacon commercial wash and let them use what they call "brightener" as it is a mild acid and will forever etch the aluminum making it prone to surface oxidation.
Today is just the tomorrow you worried about yesterday!
Pete_k
Stantonville Tn
This is the only way, Fast and easy. Buffing ball Mothers also has the wax to use with it.
Or get you a pad for a side grinder and the rouge for wheels. Its also fast.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
Gale Hawkins
Murray, KY
You may want to keep it that way by testing Red Max Pro #3 or the same product under the Zep label.
pbar34
Altadena, CA
Yep, Mothers Mag polish and a buffer will bring back the shine. I have to do my boat trailer diamond plate about every 3 years. The polish ball is okay but any orbital buffer will do. I have even used the polishing wheels that you mount on a drill.
Phil
2005 Cougar 275EFS
2001 Chevy CC, D/A
jetboat
Arizona
Mothers and a buffing ball on your drill.and lots of towels to clean the black stuff off.
swebber
Brunswick , MD
Last year I had to clean/ polish mine with a large polishing wheel and white polishing stick. The Mothers ball and polish just couldnt do it. Was dull from road chemicals after a Christmas trip thru snow and ice.
Steve Webber
'07 F250 6.0PSD LariatFX4 LB,AirLift,Edge,IFW BedSlide
'09 Jayco Eagle 324BHDS "CramalotInn III",Reese DCHP, Atwood 3500, BAL Deluxe Chocks, Weber Baby Q & Q200, Champion 2000W Inverter & 4000W gennie's
My Camping Pic's
stripit
Casa Grande, AZ
I have found the diamond plate is pretty sharp and tears the heck out of any polishing ball, pad or cloth. Once the edges are polished off and it is smooth, then hand cleaning is much easier.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'08 Lexus 400H
