While traveling this weekend a message appeared on my message center reading "Service Trailer Brake System." I pulled over checked my connection and everything seemed ok. I still had power to my fifth wheel lights, however had no trailer brakes. I unplugged my fifth wheel from my truck and plugged back in. I also tried turning off my truck and restarting it thinking that it may reset, but nothing. Has anyone experienced this. Now that I'm home, I've started my truck which is disconnected from the fifth wheel and the message keeps coming up? Any ideas???
I think these highly integrated systems will be very, very hard to diagnose
-Ben Picture of my rig
My 08 3500HD gave me the same reading about a year ago.
I could increase and decrease the relative braking indicator on the dash, but no trailer brakes. Checked everything and finally went to the dealer.
They changed the 3 wire variable pressure switch on the inboard side of the master cylinder and everything was OK.
JimL
Jim & Jane Latour
08 Chevy 3500HD, crew cab, dually, Duramax/Allison
05 Wilderness Advantage AX6 365 BSQS, Onan 3.6KY
Retired AF CMS (E9) Power Generation and Onan RV genset Level III tech
Grand Strand Sams
Blog.rv.net
