RV.Net Open Roads Forum: Class A Motorhomes: Running Direct TV Dry Camping
 > Running Direct TV Dry Camping
balfre1946
travelling
Posted: 04/22/12 10:03pm Link  |  Print  |  Notify Moderator
We are thinking of dry camping but our Direct TVs shut down when we run the generator, they only seem to work plugged in to 30/40 amps. Can you run two flat screen TVs on Direct TV directly off the generator and if so, how?
Golden_HVAC
Fulltime, CA, USA
Posted: 04/22/12 10:45pm Link  |  Print  |  Notify Moderator
I have never had a problem running mine from a generator or inverter. You might try running it from a inverter at home, and see if it might be a frequency problem. Your generator might be running a few RPM to fast or slow, and causing the frequency to change from 60 Hz to perhaps 58 or 62?
That is the only problem I can think of. A 300 watt inverter should run the direct TV receiver, it will only use about 20 watts, and leave the rest to run the TV set. You can listen to the TV in silence, especially if you have a couple of solar panels to power the batteries and inverter.
Fred.
CA Traveler
The Western States
Posted: 04/22/12 11:26pm Link  |  Print  |  Notify Moderator
It could be your gens output is out of spec: voltage, frequency or wave form type.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
jeep2relax
Lakeside, CA
Posted: 04/22/12 11:00pm Link  |  Print  |  Notify Moderator
Just a wild guess here but what happened to us was, when the air conditioner cycled the surge would reset our sat box causing it to go through the signal search and set up again. We now use precautions to make sure we don't have that issue.
Diplomat Don
Moorpark, Ca
Posted: 04/22/12 11:14pm Link  |  Print  |  Notify Moderator
You have a problem with your coach electrical somewhwere. Your DirecTv should work fine on the generator and even on an inverter. Check to make sure that the circuit breaker(s) on your generator aren't tripped. You don't say what coach you have or what generator you have.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
ryanallie1
Magalia, Calif
Posted: 04/23/12 07:09am Link  |  Print  |  Notify Moderator
Hi All.
Same here, no problems what so ever using our DirecTV while Boondocking. We can and usually do use an Inverter. But we have also used or Motorhomes 5.5 Built-In Generator. Also we have used ou EU2000i Honda/s wiht no problems either.
You must be doing something wrong. How many Hz's are your Generator putting out ?. Time to get out the old Multi-Meter and start doing some checking.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
pianotuna
Regina, SK, Canada
Posted: 04/23/12 07:21am Link  |  Print  |  Notify Moderator
Hi all,
What ever generator you do buy, avoid Boliy. Mine wont' start at 30 F. That makes it an expensive piece of metal and plastic for 1/2 the year for me.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
balfre1946
travelling
Posted: 04/23/12 07:24am Link  |  Print  |  Notify Moderator
Thanks all..what is an inverter? We have a 2010 Fleetwood Fiesta,....sorry I put this in wrong. We CAN run it off the generator bbut can we also turn the generator off and run it off our batteries?
Crazy Ray
Monroe,La
Posted: 04/23/12 07:32am Link  |  Print  |  Notify Moderator
IF you have a INVERTER you can run it off your batteries. Google 12volt side of life And read and learn. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
CA Traveler
The Western States
Posted: 04/23/12 07:51am Link  |  Print  |  Notify Moderator
An inverter uses the battery power to produce 120V AC which your equipment needs. Without an inverter your TV will only run on the gen or shore power.
