RV.Net Open Roads Forum: Class A Motorhomes: Toad Tire lock up
 > Toad Tire lock up
mtollin
Tampa Bay, FL
Posted: 04/23/12 06:22am Link  |  Print  |  Notify Moderator
Use the Roadmaster EvenBrake. Never a problem. Tow a Saturn Vue. Yesterday all 4 tires locked up. Green fuse pulled. Always worked before. First my dash sensor went off, telling me to charge battery in Vue. Said was 12.7 volts. What's wrong with that???
Then doing 60, started to slow gently and all 4 on the toad locked up. what a smoke screen. "Were" new tires, and in 100 feet wore a flat spot almost to tire wear bear. Now, $500 more for new tires.
Had battery checked, fine.
Any ideas?
* This post was edited 04/23/12 07:22am by mtollin *
Mike T.
2005 Fleetwood
Pace Arrow 37A 22W Chassis
'06 Vue Toad
sailor_lou
Connecticut
Posted: 04/23/12 07:11am Link  |  Print  |  Notify Moderator
Possible problem with the break-away setup on the EvenBrake (assuming you have that connected)?
Lou
05 Travel Supreme Envoy
Pogoil
Oregon Coast
Posted: 04/23/12 10:30am Link  |  Print  |  Notify Moderator
These kind of things seem to happen. I have personally spoke to 3 people that this has happened to with toad braking.
Pogoil.
Lobstah
Northeast
Posted: 04/23/12 10:51am Link  |  Print  |  Notify Moderator
That's one of the reasons I like the Ready Brake...no electronics, just simple cable that runs from the lever on the Ready Brake receiver to the brake pedal.
K.I.S.S. works best for me.
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
Shot-N-Az
Va
Posted: 04/23/12 10:59am Link  |  Print  |  Notify Moderator
I think there was a disturbance in the matrix yesterday. I also have the Even Brake system. Driving home yesterday, the monitor told me to stop asap because the toad was stuck in "brake" position. I had visions of burning rubber and sparking metal. Pulled over, got out, checked it out...no problem. Got in, kept going, arrived home without problems. Go figger.
mtollin
Tampa Bay, FL
Posted: 04/23/12 03:29pm Link  |  Print  |  Notify Moderator
OK.. so what type of service do you do to the connectors on the front of the toad such as the breakaway switch to make sure all are functioning properly?
PhantomFlyerSTL
Posted: 04/23/12 04:15pm Link  |  Print  |  Notify Moderator
The first time I used my EvenBrake system I received "Braking" messages on the coach monitor. At that time I attributed the problem to user error as I thought somehow I wasn't installing the EvenBrake in the car properly. Many months later I again began to receive inconsistant braking warnings when using the system. I eventually experienced the cruise control on my toad (2008 Ford Tauraus X) sometimes disengaging without warning while driving on the highway. The anti-skid sytem light eventually illuminated indicating a fault. To make a long story short, the problem was with the brake switch in my toad and not the Even Brake unit.
ClassAGeek
NYS
Posted: 04/23/12 06:14pm Link  |  Print  |  Notify Moderator
Breakaway switches are the Achilles Heel for both electronic and mechanical supplemental brakes. They are all cheaply constructed, single-point-of-failure mechanisms. As such, breakaways switches fail many times more often (probably something like 100x to 10,000x) than the towing systems they are supposed to protect.
I built a redundant signalling system on my toad. My Blue Ox mechanical cable breakaway switch is hooked in parallel to a relay connected to my 6 pin trailer connector. On my system, the breakaway switch must be tripped AND the trailer electrical connection must be broken for the emergency brake to engage.
Happy Ford F-53 Class A Owner (2008 Gulf Stream)
2010 Ford Fusion Toad (with 6 speed manual transmission - the only way to tow)
Brake Buddy Vantage, Blue Ox Aladdin Tow Bar,
TST RV 507 TPMS, Power Master Voltage Controller
crasster
Dallas
Posted: 04/23/12 06:15pm Link  |  Print  |  Notify Moderator
I personally believe in towing very light toads, and not even hooking up the breaks. By light I mean, standard Toyota Yaris etc.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
rvarner
Pahrump, NV, USA
Posted: 04/23/12 06:20pm Link  |  Print  |  Notify Moderator
Jim
X2
Richard
2002 Itasca Horizon 36LD/2008 Xterra/DEMCO Xcali-bar/Ready Brake
FMCA 394912
 > Toad Tire lock up
