rooster
somewhere in the Ocooch
Had alternator repaired on the road, tech damaged A/C hose, had that repaired, now the vacuum motor that controls dash vent controls no longer works. Unit is 99 National Tradewinds, Freightliner chassis.
any suggestions?
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
teddyu
Enfield, Ct
I'd check in the area where your heavy handed tech was. He/she could have dislodged a vacuum line that goes to or come from an accumulator. Jusy my two cents...
Ted & Carmella in the DreamCatcher a
2008 Challenger 371PE on F53 w/ 2010 Cobalt
R'V there yet?
fla-gypsy
North Florida
Vacuum line was knocked loose or damaged. Hunting it down can sometimes take some time.
N8GS
West Michigan
I would think that it is a belt driven unit so it should be hanging on the engine just like the alternator or A/C pump. As said by someone else a line may have come off or gotten kinked. If it is DC powered then it could be anywhere.
Ham radio 73's from Gale N8GS
2009 GMC 2500HD Ext cab, LB 4x4 Duramax
2006 Cougar 290EFS (RK) Axle wt 8200#, Pin wt 1760#
B&W companion
2 Honda EU2000i IOTA DLS90 converter
4-Trojan T1275's(600Ah)+470W of solar w/ Outback FM-60 CC
Samlex 2000w PSW inverter
acker1
fulltimer
This is what mine looks like:
37'--'98 Endeavor
toad--'05 Crewcab GMC
Viet Vet '65, Ia Drang Valley survivor (We Were Soldiers)
Elks
www.4ezdaz.com Same site, different URL
rooster
Thanks for the answers, but, the coach is diesel, there is no engine vacuum. It is supplied by a vacuum pump, which i could hear running in the past. Now I don't hear it anymore. Not knowing what it even looks like, or where it is located make diagnoses tricky. There must be an electrical connection somewhere, but I don't have a clue.
rooster
Acker1,
Thanks a million. I know where that is, now I can at least try something. Thanks again!!
mchero
Concord, NH
Thats a great little vacuum pump! I have one on my 93 Pace Arrow. Note the black & red wires, they are connected to a vacuum switch. These vacuum pumps "should" shut down when proper vacuum is reached. Other, more expensive vacuum pumps I have seen stay on as long as the ignition switch is on. They tend to wear out rather fast & expensive to replace.
Robert McHenry
Concord, NH.
1993 Fleetwood 36' Pace Arrow
Cummins 8.3l Turbo 300hp (uprated)
Allison 3060 Trans
2005 Jeep Grand Cherokee
http://dieselrvowners.com/forum/index.php
kneal44
EAST CENTRAL TEXAS
that pump ia a HELSA PUMP. TEST BY putting directly 12 volts to pump. to make sure it runs. then if it does search for vacuum switch. if these are not working . you can get another on ebay. search for cruise pump. i got mine for $20 delivered.
btw the pump when running makes a noise... a low frequency buzz. you will know when it works.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
