RV.Net Open Roads Forum: Towing: Michigan Towing Length Changes
Search only in Towing
Open Roads Forum  >  Towing
 > Michigan Towing Length Changes
dalenoel
S.E. Michigan
Posted: 04/23/12 08:11am Link  |  Print  |  Notify Moderator
Just read this on the MARVAC FB site.
"The Michigan legislature passed, and the Governor signed Senate Bill 35 into law on April 10, 2012. Under Senate Bill 35, the maximum length of a recreational vehicle (RV) that has its own power (motor home), in combination with a trailer, can be 65 feet. However, if the operator of the RV... has a group commercial motor vehicle designation on his or her operator’s or chauffeur’s license, the maximum length can be 75 feet.
The Vehicle Code also specifies that a pickup truck with a towing rate equal to or greater than the weight being towed, equipped with an appropriate fifth wheel assembly, towing attached with a semitrailer designed for recreational living purposes, may tow an additional trailer or semitrailer under certain conditions. Previously, the total length of the pickup truck, semitrailer and additional trailer or semitrailer, and load could not exceed 65 feet. The bill increased the maximum combined length to 75 feet.
The changes are effective immediately.
The above changes can be found in Public Act 80’12 in the Michigan Vehicle Code."
Doesn't affect me but it might some of the members.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Oasisbob
Portland Oregon 97266
Posted: 04/23/12 08:28am Link  |  Print  |  Notify Moderator
Interesting information. I know length and width allowed varies from state to state. So this can create problems when interstate traveling. I know California regularly enforces their own numbers. Seems a Federal ruling on this would better serve all concerned.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
MacRoadie
Orange County, CA
Posted: 04/23/12 09:16am Link  |  Print  |  Notify Moderator
That line should pique some interest. Not often that you see a requirement (beyond common sense)for adequate tow capacity codified.
I wonder if that means the manufacturer's tow rating, or that weird ability that seems to exist in some states wherein you can "register" a vehicle for just about any tow rating you want, until your money runs out.
Further, does that mean that if you're pulled over for questionable length, will the LEO check tow ratings and scale your rig? Does that lend any credence to the argument that liability increases when towing over capacity?
It would seem that an argument for liability is somewhat stronger when there is an attendent violation of the law.
2010 Chevy Silverado 2500HD, LT Crew, 6.0 Vortec, 4.10
2011 Keystone Cougar 26BHSWE
chevor
US/Canada
Posted: 04/23/12 12:27pm Link  |  Print  |  Notify Moderator
I have never seen a pickup truck pulling a semitrailer
2010 Gmc 2500 Duramax,1ton rear springs, 90g box tank, 0ver 497,500 Odometer miles, 20k Curt fifth wheel, 18k Curt rear mount hitch. Cobra CB/Weather Radio, Bridgestone Duravis R500 HDs Rancho 9000 Shocks, Firestone Airbags, bypass oil filter, Fass 95HD
dalenoel
S.E. Michigan
Posted: 04/23/12 12:51pm Link  |  Print  |  Notify Moderator
That might be this definition:
"A semi-trailer is a trailer without a front axle. A large proportion of its weight is supported by a road tractor, a detachable front axle assembly known as a dolly, or the tail of another trailer. A semi-trailer is normally equipped with landing gear (legs which can be lowered) to support it when it is uncoupled."
Sounds like a 5th wheel trailer in the RV industry.
BarneyS
S.E. Lower Michigan
Posted: 04/23/12 06:05pm Link  |  Print  |  Notify Moderator
Sounds like a regular TT to me also. The tongue jack is the same as the "landing gear" of a 5th wheel.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
christopherglenn
a little over an hour from Yosemite
Posted: 04/23/12 09:37pm Link  |  Print  |  Notify Moderator
(Almost) All trailers are semi trailers, wagons are full trailers - as in the only weight the TV carrys is part of the weight of the coupling device, the trailers front and rear axles support its total weight.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
