RV.Net Open Roads Forum: Truck Campers: Bargman LED stop/tail/turn light failure
 > Bargman LED stop/tail/turn light failure
monza66mo
Missouri
Posted: 04/23/12 10:49am Link  |  Print  |  Notify Moderator
My camper came from the factory with the Bargman tail lights. I noticed that the right side quit working yesterday. I took the light assembly out and near as I can tell, I have to replace the whole thing. Is there any way to repair these things? The cheapest one I found is at Tweety's for $40. Seems kinda pricy! I miss the old days when an 1157 bulb cost $1. Any recommendations?
Art in Missouri
2008 Travel-lite 840SBRX
2008 Chevy Silverado 2500
kerry4951
East Central Pennsylvania
Posted: 04/23/12 11:03am Link  |  Print  |  Notify Moderator
You are probably better off to deal with a company that sells replacements, and not try to contact Bargman. I never had any assistance or communication with Bargman in the past. There customer support is terrible.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
daveshan
Durango Colrado
Posted: 04/23/12 11:14am Link  |  Print  |  Notify Moderator
Try NAPA, they have a pretty good selection and the 4" round ones for my Lance were $17 if I remember right.
'99 Alpine 36SDS/8.3 ISC 330 Cummins
Or
'05 Lance 845
'06 Super duty SC/SB 6.0
Upgrades include: StabilLoads, Air Bags & Timbrens,Swaybars
Usually towing an '01 Wrangler, lifted/locked on 35"s or a mildly built '98 Cherokee on 33"s (only one locker)
monza66mo
Missouri
Posted: 04/23/12 11:38am Link  |  Print  |  Notify Moderator
Photog101 wrote:
I am getting ready to convert all my exterior lighting to LED and I did some checking on their warranty policies. Here is a .pdf copy of their policies.
Bargman Warranty
The warranty looks good on paper but I bet my problem would be considered wear and tear. The lights are 4 years old and worked just fine. Probably just one of those things. I have to get this road ready by next week so I'm in a time crunch.
Photog101
Garden City, Michigan
Posted: 04/23/12 11:31am Link  |  Print  |  Notify Moderator
Bargman Warranty
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
StevenH
Michigan
Posted: 04/23/12 12:03pm Link  |  Print  |  Notify Moderator
I got tired of replacing them on the tow dolly and went to led. Those round 4 inch lights are pretty much industry standard and used on the over the road trailers. Just verify if you have a plug in connector or a pig tail.
Lots of sources for them Ryder Fleet Products is one.
Good luck
Steve
97 Beaver Patriot 40'
3126 CAT, Allison 3060
Aqua Hot
AnEv942
CA
Posted: 04/23/12 10:38pm Link  |  Print  |  Notify Moderator
Well hopefully you dont end up having to run a new wire from end to end due to lack of access-gonna make that $40 sound cheap/ Sounds like you know the area though that might be problem.
I had simular episode-had to rotate right rear clearance light when I installed slide topper-arm was hitting light. Simple enough-til next time I loaded camper-blew the fuse. Took me awhile to figure when I drilled new screw hole snagged the power wire with screw. err
Good luck
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
monza66mo
Missouri
Posted: 04/24/12 04:22am Link  |  Print  |  Notify Moderator
I think the only solution is to run a new wire from end to end. There is no real access to the wires and I don't want to have to peel back the siding to get into the area that I just fixed. It shouldn't be too expensive. Just about 20' of wire.
monza66mo
Missouri
Posted: 04/23/12 05:59pm Link  |  Print  |  Notify Moderator
Good call, Mark. I took a tester out to the camper and discovered there is no power to the stop/turn wire. The tail light works. Now I have to trace down the wire and find the problem. I must have broken the connection yesterday when I was repairing some structural damage but I didn't even see any wires where I was working. Rats! I was hoping this would be an easy fix.
AnEv942
CA
Posted: 04/23/12 12:04pm Link  |  Print  |  Notify Moderator
All leds & functions quit? Didnt state so assume wiring verified working.
Mark
