RV.Net Open Roads Forum: Towing: Equal-i-zer, Reese Dual Cam, or Andersen No Sway?
Search only in Towing
Open Roads Forum  >  Towing
 > Equal-i-zer, Reese Dual Cam, or Andersen No Sway?
daystrom
NE Ohio
Posted: 04/24/12 10:06am Link  |  Print  |  Notify Moderator
Based on the Equal-i-zer, should I go with 1200 lb bars or 1400 lb bars? Equal-i-zer's web page has a calculator to determine which bars to get. When I plug in my numbers it recommends the 1400 lb bars.
2012 Crossroads Zinger ZT26BH
2011 Ford F-150 Lariat 4x4 SCREW w/EcoBoost
Lots of camping photos
coolmom42
Middle Tennessee
Posted: 04/24/12 10:10am Link  |  Print  |  Notify Moderator
You would do well to get an accurate weight on your loaded trailer before you pick a hitch. It could save you some headaches in the long run. Right now you are just guessing.
Your bars should be sized to match 15% of your loaded weight.
We are very pleased with our Equalizer. No sway problems at all, easy to use.
2006 Toyota Sienna
Single empty-nester in Middle TN
sdbounderdiesel
San Diego
Posted: 04/26/12 10:31pm Link  |  Print  |  Notify Moderator
Ditto on getting an accurate tongue weight reading with trailer in a loaded condition. Knowing the tongue weight also helps estimate the number of spacer washers you'll need for initial angle set. I got the Equalizer 1,000/10,000 to pull a 6500 lb. enclosed car trailer with about 750 lbs tongue weight. Took it on a 1000 mile trip with driving rain, strong cross winds and some tight maneuvering in the campgrounds. Worked great. Very stable. No problems at all. Especially liked that I didn't have to remove the WD bars for backing up or tight maneuvering.
daystrom
NE Ohio
Posted: 04/27/12 05:53am Link  |  Print  |  Notify Moderator
Thanks for all the comments. I've decided to get the Equalizer. Just have to get the tongue weighed for the right sized bars.
