First of all, it does not work. So for all the naysayers, you are right. Secondly, it does work, so for all the proponents, you are right.
So here is the deal. I just tried to RPM/ZEP my fiberglass Gelcoated boat. It does nothing to effect the oxidation/discoloration. Zero, Zip, nada. It never will. The only way to correct, or get rid of oxidation is by a lot of sanding and buffing. No amount of cleaning or chemicals will have any real effect on the oxidation. The only way to get rid of it, is to sand down to a fresh unoxidized surface. You can pretend all you want, but that's the facts.
So why all the rave reviews? Basically what is happening is that oxidation is primarily white. If you are working with white gelcoat that has oxidized, it has oxidized to the nearly the same color as the original white gelcoat. Therefore, if you coat the surface with something that will make it shiny, what you are actually doing is shining the oxidation. It doesn't cover it, mask it, or change it, it just makes it shiny. So really the end result is that it is difficult to see the difference between shiny fiberglass gelcoat, and shiny oxidized gelcoat, because both surfaces are white and both surfaces are shiny.
So what is the conclusion? If you are working with a white or fairly light colored surface, you can cheat the system and make oxidation shiny. All well and good, and worthwhile. BUT here is the warning. If you are dealing with a dark surface that is oxidized, making the oxidation shiny means that now you have faded, light grey colored ares that are shiny. It does not make those grayish white oxidized areas dark again like the original color. If you have a dark color that has turned light grey, do not waste your time covering it with RMP/ZEP. Because that is exactly what you are doing, you are wasting your time. Not only that, but then you have to strip it all back off again, and then do the actual work of sanding, polishing, and buffing. Once you have sanded all the oxidation off, then it may be worthwhile to put a final coat of RMP/ZEP on it, as the product does shine. But if you are starting with an oxidized dark color, you have to do the hard work.
I just re-did a dark blue boat that was heavily oxidized. I made the mistake of thinking I could play the game, clean it, and coat it with ZEP. I ended up having to strip the ZEP back off, go back and wet sand the surface, and rub it out. When I was all done, I did end up recoating it with ZEP, so the end result looks good, but it took me a lot longer to get there and required a ton of sanding. Hopefully this information will save someone some time. Its not that hard to strip it off when you've discovered it doesn't work on dark colors, but it but it wasted one of my weekends - mainly because I put on about 5 coats, hoping that it would eventually darken up. (like what you see when the surface is wet). Incidentally the top white part of the boat looks good.
I plan to do the motorhome next. Because it is a light color, I believe it will work just fine, without having to do any sanding.
Dave
The Flying Fortress
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Howell/GM 16197427 ECM/Edelbrock MPFI,Thorley's & Magnaflows,
4L85E 4 speed, KoniFSD,
6% grade = wanna drag? MISC photos Revconeers Forum
Dave,
Did you do the cleaning with the Bar Keepers Friend cleanser first? That scrubbing is the first part of the required steps. That is suppose to remove the oxidation. You should be able to feel the oxidation with your hands. Don't RMP it unless the oxidation is gone. At least that is what I understand.
Yes, I did. The surface was pretty smooth and somewhat shiny before the first trial. Bar Keepers friend would hardly touch the surface. I ended up trying to use it with a orbital buffer. Still really would not cut it. I think with light surface, you don't see how deep the oxidation is. There is oxidation on the surface which is chaulky, but then there is discoloration that can go pretty deep. The white areas were probably oxidized just as bad, but you don't see it, so once coated, they look good.
Daveinet wrote: First of all, it does not work. So for all the naysayers, you are right. Secondly, it does work, so for all the proponents, you are right.
Which is why almost every thread stresses PREPARATION !! Wash with something like Dawn to cut all the grease etc., then use Bar Keepers friend to remove the oxidation ( it does work.) then apply the RMP/ZEP
I wouldn't be too quick to fault the final product if you didn't do the prep work properly.
Kinda like taking a car thru the carwash and then painting it and blaming the paint because it flaked off.
Many have had very good results on both light and dark surfaces using RMP.
hershey - albuquerque, nm Someday Finally Got Here
Superman was an illegal alien.
The gold on my 5er was almost white. I cleaned with Barkeepers friend and coated with RMP. It now looks like I had painted it and it has been close to a year since coated. I think you just failed in your prep work. I do know a little about gelcoats and paint as you can see in my sig.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs-28years
We love 56 T-Birds
So if you are going to question my prep, how much cleaning with Bar Keepers Friend do you believe it would take? I started with Bar Keepers Friend doing it by hand. Since it was not making any difference, I switched to the orbital. That still did not make any difference. Basically the Bar Keepers Friend was also pretty much a waste. It may work for soft paint, or to remove chaulkiness, but it really doesn't do much for oxidation. Gelcoat is porous. Oxidation penetrates deep into the gelcoat. Cleaning the surface, or even cutting into the surface slightly with a rubbing compound like Bar Keepers Friend, is not aggressive enough to get through the oxidation and remove it.
BTW: I also tried regular rubbing compound, which is much more aggressive than Bar Keepers Friend. This still would not cut through the oxidation.
I would guess that the boat had gone past the point of no return as far as the oxidation was concerned. The process used for RMP is for normal conditions of oxidation.
The OP did use RMP after sanding the oxidation and was satisfied.
It is obvious from your discription you needed much more than a simple cleaning with Bar Keepers Friend, and blaming the RMP for your failure to properly clean the service is not fair to that product. In some bad cases the work to remove the heavy oxidation is extremely hard and time consuming. But once that surface is restored, using a durable hard shell type finish like RMP would make your boat look like new. So looks like your going to have to start over to obtain the look you want.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'08 Lexus 400H
Daveinet wrote: So if you are going to question my prep, how much cleaning with Bar Keepers Friend do you believe it would take? I started with Bar Keepers Friend doing it by hand. Since it was not making any difference, I switched to the orbital. That still did not make any difference. Basically the Bar Keepers Friend was also pretty much a waste. It may work for soft paint, or to remove chaulkiness, but it really doesn't do much for oxidation. Gelcoat is porous. Oxidation penetrates deep into the gelcoat. Cleaning the surface, or even cutting into the surface slightly with a rubbing compound like Bar Keepers Friend, is not aggressive enough to get through the oxidation and remove it.
you are doing something incorrectly. I can get BKF to cut ANY oxidation. Start with a small area. You can also purchase fiberglass hull cleaner. Lil more aggressive than BKF but works really well.
